View Poll Results: Bosch or SVO injectors?
Bosch
100.00%
SVO
0%
Voters: 1. You may not vote on this poll
Bosch or SVO injectos?
Hey everyone. I have a set of 24lb SVO injectors which used to be on the car. I took them off while trying to diagnose a fuel problem (wound up being pump/pulsator) and wound up replacing them with Bosch 24lb from Southbay. In my internet travels I've read that the SVO's are better than the Bosch. I'm going to be doing some work this spring and was thinking about replacing the Bosch with SVO's. Thoughts?
Current setup: 350 TPI, Crane 2032 cam, Summit brand aluminum heads, SLP runners, Accel Base manifold, Hooker Headers, and will be installing 1.5 roller rockers soon.
Thanks everyone.
Thanks everyone.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bosch or SVO injectos?
Datalog and see how your fuel trims are. More than likely your a hair lean. Increasing fuel pressure with a adjustable fuel pressure regulator or tune .
You've got Ford injectors either way. The SVO injectors are aftermarket Mustang injectors. The yellow/orange Bosch IIIs everyone buys are 5.0 Explorer injectors. Ford rates their injectors differently. A 24lb/hr Ford injector doesn't flow 24lb/hr in a TPI system.
You can tune either to work, or go with a stock replacement for TPI if you want it to work like stock. Given the mods, probably need the tune anyway.
Engine: Lb9
Transmission: M20
The ford blue tops are much quieter than b3s.
i think I did do a tune for you. Pm me if I can help tuning
They are more quiet than the bosch lll's, however they do not make them anymore. You'll have to get a set of used ones. If they are listed as new be careful as they are more than likely from China.
Luckily these are used ones, so they're not China re manufactured ones.
Jas89TTA
Mar 9, 2001 10:54 AM
