Did I fix the problem, or just cover the symptoms?
Old Jan 14, 2002 | 02:12 AM
Reno's Avatar
I bumped my fuel pressure up again to where it was when I got the car (60 PSI, according to the gauge at the schraeder valve), and all my cold start/crappy running problems have vanished.
Should I assume the gauge is crap, and lowering my fuel pressure was the problem to begin with, or is turning up the FP masking another more important problem here?
-Reno
Old Jan 14, 2002 | 02:22 PM
Snap Draggin's Avatar
You might check the pressure with another guage. I'm inclined to believe that it truely needed that pressure. If you have access to an O2 sensor tester, see if the cross-counts look normal, if so just let it ride.
Old Jan 30, 2002 | 06:01 PM
FoREEL's Avatar
60psi is alot!!!!! Might look into it!
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
