91+ ASM Runners on an 88?
Old Aug 4, 2020 | 02:46 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I am considering buying a set of AS&M runners for my SC'ed 88. I have went to EBL and am using updated tuning. The 9th injector is no longer in play for me.
Can I use a later set of runners with my plenum and base?
My injectors are flashing to 100% DC and if I am tearing it apart for new injectors, might as well put bigger runners on it. Just want to get the right set. I obviously do not plan on using the 9th injector moving forward.
Old Aug 4, 2020 | 03:43 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: 91+ ASM Runners on an 88?
yes
Old Aug 4, 2020 | 06:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yes, make sure you plug the small runner tube/port on the driver side if it is there.
DreamState21x
Nov 1, 2002 07:57 PM
