lt1 intake swap
Old Jan 15, 2002 | 06:42 AM
CORKVETTE1's Avatar
lt1 intake swap
what are the good years and makes they are on i heard 94 and up vettes, camaros, impalas and roadmasters correct me if iam wrong
Old Jan 15, 2002 | 11:01 AM
GhoSSt's Avatar
The only problem with the Vette intakes is that the fuel rails point towards the passenger side. Since you have to fabricate new fuel lines anyhow this isn't a big deal, but you have to run longer lines and that increases cost and pain in the *** factor.
1992/93 rails can be used and the intake itself is a little nice and the castings are higher quality, but they require more work to make fit.
So basically, the easiest, cheapest way to procees are 1994+ Caprices, Fleetwoods, Roadmonsters, and F-bodies.
Old Jan 15, 2002 | 11:40 PM
CORKVETTE1's Avatar
what kind of more work i was thinking about doing what you did to that one intake cuting off all of the egr stuf to use the big dist so what all do i need to look for or know i dont understand what you are talking about fuel rails comeing in from the sides you mean i can not use any of the vette intakes or what any info would be appreciated
Old Jan 16, 2002 | 12:19 AM
GhoSSt's Avatar
First, here:
Some extra periods, since you seem to be missing that key on your keyboard.
OK. Pay attention, theres gonna be a quiz later.
F/B body fuel rails exit pointing towards the driver side of the car.
Y body (Corvette) rails exit pointing to the PASSENGER side of the car.
Since the fuel lines on a TPI F-body come up on the drivers side of the car, it easier to have fuel rails that exit, pointing that way.
Get it?
Got it?
GOOD.
Yeesh®
Kelly 'GhoSSt' Rosato
Old Jan 16, 2002 | 12:58 AM
CORKVETTE1's Avatar
ok ok i got it. but i should have said i am working with a l98 corvette and my fuel lines are comeing up the front on the slight pass side.so could i use the vette manifold or not . i mean is there any thing going to be in the way for the mods. where exactly does the adj fuel pressure reg go. i am sorry for my lack of knowledge on this subject i have seen hundruds of lt1 vettes and count less f bodys but never gave it a thought how this will all go together. i am planning on doing the swap i just dont want to do it two or three times just once thanks
Old Jan 16, 2002 | 01:13 AM
GhoSSt's Avatar
Much improved.
Thats why I was talking TPI F-body.
OK, then you'll prefer having Vette fuel rails too. The AFPR still fits on the drivers side rail tho.
KR
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
