White smoke on acceleration while in park - advice
Old Aug 30, 2020 | 03:05 PM
Sn8k09's Avatar
I literally just got this engine to turn on after 16 plus years of sitting...
90 iroc 5.0 tpi.
it is not coolant as I temporarily have just water in radiator
turned on in park at idle is fine, when I press the accelerator it smokes clouds of white.
let it run for about 10 min.
new injectors
new radiator
new engine oil, I checked and I think it’s over filled
new fuel pump
any advice before a compression test?
Old Aug 30, 2020 | 03:12 PM
ULTM8Z's Avatar
Re: White smoke on acceleration while in park - advice
Three sources of smoke on an engine since there a three fluids running through it.
Fuel - black smoke if too rich
Oil - kinda blue-ish smoke of youre burning it.
Coolant - steam... its not really smoke
Old Aug 30, 2020 | 11:28 PM
GeneralDisorder's Avatar
Plain water will still smoke white. As mentioned this is steam. Actual coolant is not necessary.
Possible it was parked due to a head gasket failure?
GD
Old Aug 30, 2020 | 11:53 PM
Sn8k09's Avatar
It could be, will be doing the compression test tomorrow.
Old Aug 31, 2020 | 08:41 AM
Compression test may not show a significant change. Need to check for exhaust gasses in the cooling system.
GD
Old Aug 31, 2020 | 11:40 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
90 iroc 5.0 tpi.
new injectors
new radiator
new fuel pump
Water is also classified as a 'coolant.'
A much more definitive diagnostic would be a leakdown test rather than a simple compression test.
Old Aug 31, 2020 | 05:41 PM
NoEmissions84TA's Avatar
You put water in the radiator, but unless you completely drained the block (lower plugs on either side), there is still antifreeze circulating - just more diluted than before.
Old Sep 1, 2020 | 09:03 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
As mentioned, even pure water will look white if excess amounts are being turned to steam in the combustion process. I think it's a leak down test you are going for instead of the compression test. Pulling plugs will also help you find the issue if you had it running for a a few minutes. One won't look like the rest.
Old Sep 1, 2020 | 11:03 AM
Sn8k09's Avatar
GD
more than likely now that you bring it up, I was being optimistic That maybe it was parked due to the fuel pump.
Old Sep 1, 2020 | 11:08 AM
Sn8k09's Avatar
I will be pulling the plugs tonight and inspecting them, I don’t have the tools for a leak down test , however since I ran it again yesterday for 15 minutes at idle I then Found oil in radiator, no water in oil though.
I’ll post picture from plugs but I may just start dissembling it this week.
thanks
Old Oct 21, 2020 | 12:15 AM
project85irocz's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 305 TPI LB9
Your problem is probably the valve stem seals. I had this same issue and replacing them solved this
Old Oct 21, 2020 | 07:17 PM
Sn8k09's Avatar
That seems to be it, just finished reassembling it, since I had heads out I went ahead and put new rings in, new head valve seals and of course head gasket. All put together now and turned on a few minutes with no smoke . Busy with work and have been doing this in my free time. Thanks
TPI89irocz
Apr 21, 2011 09:13 AM
Thestriped1
Feb 24, 2007 01:12 AM
Sinisterdrummer
Aug 28, 2005 09:27 PM
Canyaro
Jan 18, 2005 09:31 PM
nebulous
May 11, 2004 11:48 AM
