Low and high idle
Old Sep 4, 2020 | 11:19 AM
BenCramer98's Avatar
Car: 1986 z28 camaro
Engine: 305 tpi
Low and high idle
My 86 tpi camaro has always from brand new idled at two different speeds. One faster and the other slower. Was this an error from the factory?
Old Sep 4, 2020 | 01:29 PM
ULTM8Z's Avatar
Re: Low and high idle
Idle speed always varies with coolant temperature for any gasoline powered car.
Old Sep 9, 2020 | 09:00 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
What ULTM8Z is saying is correct, depending on coolant temp the ECM will target a different RPM to idle at.
Additionally there are two idle speed classifications. One is in P/N the other is in D or in gear.
There is also a bump in idle for AC.
If what you are experiencing relates to the above conditions, everything is perfectly normal. If not, please provide more detail of what you are experiencing.
mikej
May 6, 2009 04:48 AM
86z28iroc-z
Oct 13, 2006 08:41 PM
Jschoepf
Carburetors
Apr 13, 2005 09:22 PM
