Test mass air flow sensor
Old Sep 26, 2020 | 09:52 PM
Gizmoz28's Avatar
Transmission: 5 sp
Do you test when running or with ignition off
Old Sep 26, 2020 | 10:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Test mass air flow sensor
What's you're issue?
if odd things, unplug it, preset values are used...if it runs better, then maybe MAF of a flakey MAF relay...i/e air going in confusing the incoming air reading.
I don't recall, but without a scan toon you can see what the MAF is reporting, what I can't recall is the numbers you should see on the scan tool. All my babbling aside, unless you see something visually wrong looking through the screens, I don't know of a way to test it with with engine off.
Old Sep 27, 2020 | 09:33 PM
Vader's Avatar
A running test can be perfomed with a voltmeter.
Gizmoz28
Oct 5, 2020 03:40 PM
1987ZTPI
Jan 9, 2008 01:13 PM
TPI TERR
Oct 11, 2005 04:38 PM
Xplod
Jan 23, 2002 01:49 PM
