Idle air control valve problem?
Old Apr 13, 2018 | 02:08 PM
Adrian2898's Avatar
Car: 1989 camaro iroc-z
Engine: 350 tpi
I got my engine rebuilt last week and ever since the car just keeps turning off after I drive it for more than 10 min. I will pull up to a stop sign or red light and the revs just fall to 400 rpm. I had them install a bigger cam so will it need tuning for it to run smooth and not shut off? Could it also be the IAC valve that need to be replaced or a vacuum leak? It also shuts off when I've been driving it for 10 min and I put it into reverse or park. Thanks. These are my cam specs
Old Apr 13, 2018 | 02:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Idle air control value problem?
Sounds like a heat related issue. Have you checked fuel pressure ?
Does it fire right back up after it stalls ?
The cam does need to be tuned for but I don’t think it’s the main issue for the engine dying.
The engine could be flooding if you installed larger injectors you can always do a plug read.
Old Apr 13, 2018 | 02:34 PM
Adrian2898's Avatar
Engine: 350 tpi
Yes It starts up right away and I installed bigger injectors too
Old Apr 13, 2018 | 02:35 PM
Engine: Lb9
Transmission: M20
It could be loading up you might want to read the plugs.
Old Apr 13, 2018 | 02:47 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You might want to do the IAC Reset procedure first.
Follow this:
https://www.thirdgen.org/forums/tpi/...988-trans.html
Engine: Lb9
Transmission: M20
Have you watched the int and blm ?
You will need to get a aldl cable with a 10k mode to tune the cam.
http://www.moates.net/aldu1-and-cabl1-p-127.html
Here’s a good deal but you need a g1
https://www.thirdgen.org/forums/engi...equipment.html
Old Apr 13, 2018 | 02:58 PM
Engine: Lb9
Transmission: M20
You can also adjust the Iac steps to 20-25 at idle using a scan tool or tuner pro rt.
Old Apr 14, 2018 | 09:43 PM
moneyman380's Avatar
Car: 1991 Z28
Re: Idle air control valve problem?
Did you figure out the issue? I'm having similar problems
Old Apr 14, 2018 | 10:04 PM
Adrian2898's Avatar
Engine: 350 tpi
no I haven't, but I'm going to try and reset the idle control valve and see if that works.
Old Apr 15, 2018 | 07:38 AM
Vader's Avatar
Clean the IAC and air passages first. Then clean the throttle body, both the bores and plates.
There is no such thing as a "reset" of the IAC on a TPI. It is under full control of the ECM.
Old Apr 15, 2018 | 06:21 PM
Adrian2898's Avatar
Engine: 350 tpi
oh ok thanks a lot
Old Sep 20, 2020 | 04:14 PM
Toddler007's Avatar
Did you ever solve this problem? I am having the same issue and can’t figure it out.
Old Sep 24, 2020 | 06:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That it stalls. or you put together an engine with a bigger cam/etc?
Does your SE light come on, and have you pulled codes? There was a how to in the tech section here years ago, but if no scan tool, a paper clip between the Far right upper and lower (I think) terminals and turn the key to on (don't start it) will give the flashes...so flash-flash.........flash-flash-flash, would be a 23, it will flash the code 3 or 4 times, then flash the next code set. Probably a better explanation on top, but all I got now
Old Sep 25, 2020 | 08:29 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
It should always flash Code 12 first
@Toddler007 we need more information to help you. As Mike asked, are you in the same boat with a bigger cam and injectors or are you having issues on an otherwise stock engine? As mentioned above, the first step is to always clean the IAC and housing, then perform a min idle reset procedure. If you are not using a system to read and log data, troubleshooting will be much more difficult.
Old Sep 26, 2020 | 10:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Good point, as I recall, Code 12 will be there when checking because the key is on, and no ignition pulses seen...so just assume it will be there at every paperclip code check.
Old Sep 28, 2020 | 10:06 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
If it is not, bad ECM
QwkTrip
Mar 30, 2026 08:49 AM
JamesC
Carburetors
34
Jun 17, 2018 08:04 PM
gcj280
Apr 25, 2017 04:43 PM
Lucid
Mar 7, 2009 07:36 AM
Vader
Mar 16, 2002 10:58 AM
