Cold start and low rpm issues
Old Oct 4, 2020 | 11:32 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So my build is 383 with mini ram, accel 1000 cfm tb, and accel gen 6 DFI. I think my map sensor is bad but wanted some input. Basically when cold starting it does crazy rpm hunting and even stalls out sometimes. It will idle between 400 and 1200 rpm until warm and then it will idle beautifully at 800 rpm. Seems to also run rich. also, when driving on highway, at 50 mph or higher, if the RPM's get too low like 2200 the whole shakes very violently like the engine wants jump out the engine bay. Very scary and because of that I haven't been using overdrive and have been keeping RPM's at or above 3000. Could MAP sensor also cause that?
Old Oct 5, 2020 | 12:25 AM
GeneralDisorder's Avatar
Re: Cold start and low rpm issues
Sounds like tuning issues. Have you had it professionally dyno tuned?
GD
Old Oct 5, 2020 | 12:47 AM
msammy93's Avatar
Engine: 383 TPI
GD
No, I bought it like that and it uses the old gen 6 accel DFI ecu. Not sure anyone has computers to tune those nowadays
Old Oct 5, 2020 | 10:12 AM
Likely most people (including me) would recommend replacing that system.
We can't solve your problem or suggest a troubleshooting path since you are unable to communicate with the fuel computer and you have an entirely custom setup.
GD
Old Oct 5, 2020 | 10:16 AM
msammy93's Avatar
Engine: 383 TPI
GD
Yeah I was looking into replacing the DFI ecu with a EBL P4. I saw you could buy it from the manufacturer with the 7730 ecm modified already. Will the 7730 ecm work with an 88 trans am? My car does have a MAP sensor, but I see the computer listed as a 90-92 firebird only.
Also, is there another computer that is plug and play besides the EBL P4 that you guys recommend?
Old Oct 5, 2020 | 10:41 AM
The EBL Flash II is the system they make for 86 to 89 cars.
Depending on how much functionality you want and your budget there are other options like the LINK G4X that I'm running with a harness adapter.
GD
Old Oct 5, 2020 | 11:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah definitely sounds like the tune is not right. Hard to say without knowing more details. If the software can run on a modern computer then it can be used. If not then maybe try to find a used or refurbished old laptop with the right windows version that can run it and attempt to tune it from there. Im not familar with those systems and how they datalog and program, i assume it should have its own cable, serial or usb port
Matthew91-Z28
Mar 7, 2010 11:09 PM
GokuZ06Roc
Feb 12, 2005 07:24 PM
scott8950
Apr 2, 2004 08:55 PM
