4th gen fuel tank
Old Oct 13, 2020 | 05:49 PM
UKPROCHARGEDGTA's Avatar
Car: 1989 Trans Am GTA
Engine: Procharged 350tpi
Transmission: uprated 700R4
4th gen fuel tank
have heard 4th gen tanks are better (baffled and plastic) anyone know if all are better or just later LS engined ones
Old Oct 14, 2020 | 12:15 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: 4th gen fuel tank
I have one off 01 camaro and theres no baffling inside tank. The fuel pump module however has a fuel bucket I suppose to keep the pump fuel of fuel when cornering.
Old Oct 14, 2020 | 12:37 PM
Thirdgen89GTA's Avatar
Transmission: M28 T56
If you need a fuel tank, its not a bad thing. But you'll need to mess with the sender because the resistance range is different. Its documented somewhere on the boards. Can't remember where, but search will find it.
Old Oct 14, 2020 | 04:57 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It is a superior tank for cornering since the pump is in a bucket, it will also never rust.
It is slightly heavier than the steel tank though, only a couple pounds though
Old Oct 14, 2020 | 06:17 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I did an 02 tank in mine. If I remember correctly, you just swap out the little cardboard resistor strip on the sender to get the gage to read right. My latest iteration uses an later model ECM that will provide my fuel level so I kept the LS1 sender but bent the float rod 180 degrees so the resistance reads in the opposite direction...not necessary for the stock 3rd gen gauge.
451stroker
Sep 25, 2019 11:22 AM
gearheadotaku
Jun 12, 2014 11:01 AM
Rich2279
Aftermarket Product Review
Apr 11, 2008 09:16 PM
craig
Carburetors
Dec 5, 2007 10:03 AM
irocz2889
Nov 23, 2007 09:46 PM
