MAF readings
Old Nov 2, 2020 | 11:04 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
MAF readings
Ok my new OBD bosch 1300 scanner came in today. I was doing sone live data and found the MAF readings to be like 2,000. I unplugged the NAF and the readings were at 3,000?
i thought it should be around 7-12 at the most at idle?
do you think the MAF is bad? Im not sure what the relays do but i assume they work since the readings are changing? See below pic for maf reading right under loop statis
thanks guys!
Old Nov 3, 2020 | 07:04 AM
GeneralDisorder's Avatar
Re: MAF readings
Something is wrong with the scan tool translation of the data. MAF can't exceed 255 grams per second. It's an 8 bit value.
GD
Old Nov 3, 2020 | 11:14 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: MAF readings
GD
dang it....so you think my new scanner already junk?? Lol
Old Nov 3, 2020 | 11:40 AM
Re: MAF readings
I think they likely have never tested it with some old 80's ALDL protocol and have copy and pasted themselves into a bug in the scan tool firmware. Check with Bosch for firmware updates.
GD
Old Nov 3, 2020 | 06:44 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: MAF readings
GD
Thanks GD!
I will /am looking into that right now!
2kickassbirds
Apr 12, 2008 05:45 PM
1987earthquake
Dec 21, 2006 05:39 PM
DannyT
Jan 2, 2004 06:37 PM
DannyT
16
Oct 31, 2003 11:49 AM
Matt87GTA
Jun 13, 2002 06:09 PM
