Carburetor to TPI Conversion
Old Dec 15, 2020 | 07:20 PM
JessieRS's Avatar
Car: 1986 Camaro
Engine: 305 5.0L
I have a 1986 Camaro with an original carbed 305 in it and I've been really wanting to swap it out for a TPI setup. What all would I have to buy and swap out?
Old Dec 15, 2020 | 07:41 PM
ULTM8Z's Avatar
Re: Carburetor to TPI Conversion
I don't know if you want TPI for the sake of maintaining the 3rd gen look and feel, but if you're going to through the effort of an EFI swap... I'd get an LSX style engine and do that.
Old Dec 15, 2020 | 07:55 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
What reason are you wanting to change to a tuned port?
Power wise, the tuned port manifold will become a restriction pretty fast. The carb set up less so and is cheaper and easier.
Fuel mileage wise, the quadrajet can be dialed in to get similar mileage and reliability.
Appearance wise, tuned port looks cool. Well, I can't argue with that.
Old Dec 16, 2020 | 08:00 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i've done this in the past to my 86, i wanted to supercharge it. i converted to TPI it was so much better than that carb!
a lot needs to change to get it to work. if i was to think about doing this today. i would do an entire LS swap. which i did. it now has a lq9 6.0 in it that is far superior to the supercharged 305 tpi i had.
Old Dec 16, 2020 | 08:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Save your money for a Holley Sniper setup and never look back. Don't bother with newer GM ECU's, wiring, tuning, etc, its a waste of time... especially when starting out with a carb setup. The Holley Sniper is where it's at. Whether 305, 350, 400, 454, whatever you put under it now, later, or never, it's still the way to go. Otherwise you'll be pissing your money away trying to replicate an older inferior system, or you'll be chasing your tail trying to emulate a newer system.
- Rob
Old Dec 16, 2020 | 04:05 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
- Rob
This is good advice
Old Dec 17, 2020 | 07:38 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I don't recommend this; it's just not practical for a number of reasons.
Old Dec 19, 2020 | 06:33 PM
thebandit50187's Avatar
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
I did the swap a few years ago. I have a 1987 Formula that originally came with a LG4. Shortly after I bought the car, the engine kept overheating and would develop Hotspots and every time it would overheat, the engine would start to leak at the freeze plugs. When one between the engine and transmission started leaking I decided the engine needed to go. A few months later I had a TPI engine fall in my lap. It came with the engine, harness and 7730 ECM. The engine was actually a LO3 long block with a 1987 TPI intake. I had to modify the harness of my car and the engine only because I went from v belts to serpentine. I also re routed the fuel lines and used EFI hose from about the driver sear underneath to the engine because carb lines cross Overtop the transmission and go to the passenger side where EFI stays on the driver side. I should of upgraded to a 88 and newer fuel rail because of the accessories and brackets are different but I made what I had work. I put in a fuel pump for a TPI as well. I hear 1986 should already have a small pusher pump in the tank like the 1987s. Just swap that for the TPI unit. If you get TPI, get a harness and ECM for your model and year.. it will be plug and play. I had to make an adapter for my C207 connector.. something had to be left out and somethings had to be added and powered. If you can get the stuff cheap, its worth the cost in better fuel economy. Its not hard and you don't need an expensive EFI or LS swap. Though they are options
1bad88droptop
Jun 22, 2005 11:06 AM
LittleNo
21
Apr 25, 2005 07:20 AM
BuckeyeROC
Aug 30, 2003 02:29 AM
