tpi intake gasket
Old Jan 15, 2002 | 10:47 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
tpi intake gasket
I need to install new intake gaskets because the frnot driver's side went bad and coolant leaks out like a fountain there.Is it hard to do it myself and how much are the gaskets?I have the tools to do it.
Old Jan 16, 2002 | 11:33 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
you should have no problem installing that it is really easy. i put my whole TPI setup on my car when i was only 16. If you are gonna do it you better do it right with a felpro gasket set go to ebay you can purchase one for like 15 bucks and it will replace every gasket on the tpi system. they are really good gaskets too. i recomend them. you may want to but a new bolt set too i dont know but it really cleans it up.
Old Jan 16, 2002 | 06:19 PM
BlazinOR's Avatar
Where did you get this 'bolt set' and what was the cost? Doing an injector swap this weekend and will have it all torn down anyway.............
Old Jan 16, 2002 | 07:52 PM
91-ZZ4-Z28's Avatar
I have used several different brand intake gaskets and the best I have found are Victor Renz I got them from Lingenfelter for 12 bucks.
Old Jan 17, 2002 | 01:18 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Yes you can find the bolt set on ebay along with the gaskets just type in "tpi bolt set" and it will take you there you will have a choice of stainless steel or black i suggest the stainless its like a dress up kit for the tpi. have fun with that injector swap sounds like fun but dont forget the cold wrench!!!!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
