FPR Removal
Old Jan 16, 2002 | 09:44 AM
IROCKER's Avatar
FPR Removal
Ok, I'm stumped...what tool is needed to remove the old FPR? A T10 torx fits the hole, but in the centre of the hole is this little stub. Is there supposed to be a special tool for this?
Old Jan 16, 2002 | 09:47 AM
BitchinCamaro's Avatar
Yep, you need to get "tamper proof" torx bits. DAP carries them, but beware they are not very strong. I broke one on a hand tightened runner bolt. I think you can knock the stub down with a punch, but I have never tried that.
Old Jan 16, 2002 | 10:33 AM
IROCKER's Avatar
Knocking the little stubs down with a punch is what I was considering doing, but I'll take a look for the tool first. Thanks.
Old Jan 16, 2002 | 06:23 PM
BlazinOR's Avatar
It's a T-10S bit if you are looking for one at a tool store. In a pinch, vise grips will remove them (ask me how I know this), then replace them with regular bolts/allen heads, etc.
Old Jan 17, 2002 | 09:20 AM
IROCKER's Avatar
Thanks Blazin, I actually considered that too ...the vise grips and then replace them with normal screws. But I ordered the bit from the parts store, it was only $5 so no biggie.
Old Jan 19, 2002 | 05:41 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
all i did was take the torx bit, hit it with a hammer and knock the center down.. worked perfectly... and cheap..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92-Formula
Dec 12, 2015 10:34 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Strick1
Sep 4, 2015 07:11 AM
