L98 Injector Replacement
Old Apr 5, 2021 | 03:52 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Well, I’m finally tearing my L98 apart to replace the fuel injectors, and it’s a real mess.
Half of the runner bolts I discovered are missing, most notably, the two that go in from behind.
I also discovered that 19 lb/Hr Rochester injectors had been installed, and based on the dirt going all the way to the bottom of the injector bores, I suspect they came from a junkyard, and were installed without lubrication, or even new O-rings. I’ve found potential air leaks everywhere.
The injectors themselves were a mess. One tip was broken, another cracked, and I’m honestly surprised it was running at all.
I have new Delphi drop in replacements, 22 lb/ hr, that I got from Southbay. I have high hopes that the car will run much better once they’re in, and things are put together properly.
Old Apr 5, 2021 | 05:44 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: L98 Injector Replacement
Whew, I thought my TPI setup was pretty gnarly, but those just look trashed. Good call on the replacement.
Old Apr 6, 2021 | 01:37 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Those look pretty terrible. The Delphi's are a nice quality injector that should work great for you. While you are in there, I would also recommend getting a fuel rail o-ring kit and a new fuel pressure regulator and rebuilding the fuel rail assembly. Southbay also carries the o-rings and fuel pressure regulator.
Old Apr 13, 2021 | 07:05 AM
Car: 1988 IROC-Z
All buttoned up, and running. The Delphi injectors are slightly noisier than the old Rochesters, but the car is running great!
Old Apr 13, 2021 | 07:09 AM
Car: '89 GTA
Engine: ZZ6TPI
Travis11394
Sep 12, 2019 10:55 AM
Shakenblake
Sep 23, 2017 01:35 PM
Gran Torino
Feb 9, 2016 04:44 PM
Allan
Sep 22, 2000 10:57 PM
