Fuel Pressure Regulator - 65 PSI
Old May 7, 2021 | 12:00 PM
MrMathers's Avatar
Car: Frankenstein 84-90 Iroc.
Engine: 355 TPI, Big Cam.
Hey, I don’t know if I’m over thinking this. But been having a fuel delivery problem. L89 87 Style Tpi. (Frankenstein build) I had a Bbk adjustable fuel pressure regulator that had a bad diaphragm. Couldn’t get consistent pressure at the rail. It was all over the map. I found an ORM Styler FPR around the shop and went ahead and put it in. But now I’m getting 65 psi at the rail on prime, it will start and run for a few minutes but then fouls the plugs and dies. Just got done building the motor, trying to get it broke in. I’ve blown out both lines with an air compressor. It’s a new fuel pump. But it’s not like a high flow or anything. I haven’t clamped the return lines yet and primed the pump yet. I’m at work and I his is just eating at me. Would a faulty FPR be the culprit here? Also there is no fuel running out the vacuum line off the FPR when it’s running. Before I went out and bought a diaphragm or another FPR. My brain looks just isn’t working today and was seeing if anyone can help clear it up. Appreciate it.
p.s if I do need to get another FPR, what are your recommendations? I have the BBK one still, just needs a diaphragm. But I’m not entirely too impressed by it honestly. Running 24 lb injectors, so I shouldn’t need anymore then stock pressure. Just keep the original FPR and get a new diaphragm? Appreciate the input. First TPI build. Not the first sbc build, but first time working with the Tpi.
Old May 7, 2021 | 04:01 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: Fuel Pressure Regulator - 65 PSI
pretty much either your FPR is bad if it is really the correct OEM type, not set correctly if adjustable, or you have a block somewhere in the return circuit
Old May 8, 2021 | 01:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
29.3#hr with increase pressure will really require ecm tuning.
88astrotpi
Feb 9, 2016 04:50 PM
Seedy Al
Feb 15, 2010 01:56 PM
mike89z
Jul 20, 2003 03:35 PM
CamaroX84
Sep 24, 2001 08:01 PM
x5finger
Jun 4, 2001 11:51 PM
