Anyone with the Vortec TPI base....I have a few questions....
Old Jan 16, 2002 | 08:31 PM
CamaroX84's Avatar
Does it come with intake gaskets? Does it come with intake bolts? If not, can I use all the stock ones on the Fastburn heads? Thanks.
Old Jan 16, 2002 | 09:16 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
SDPC Manifold
It does not come with gaskets or bolts. But it does require special bolts that you can get from the dealer.
Old Jan 17, 2002 | 12:15 AM
Earl 87gta's Avatar
Dont use their bolts They just give you a set of ARP bolts to use I have arp 12 point and they work fine as far as gasket goes they do not come with them you can use a set off a 96 gm truck with 350 or get the felpro one I would use the felpro. One other thing if you are not going to runn egr you will need to block off the egr holes you can buy these from TPIS or make your own.
Old Jan 18, 2002 | 07:43 PM
Greg90iroc's Avatar
ok if you get the bolts from scoggin they have actualy been made for the vortec heads and the manifold they have diffrent heads if i remimber correctly. I remimber being in there when the first prototype came in. They actualy fit nicer. but it is up to you. Yes they are from ARP but they are specialy made for the vortec heads.
Old Jan 18, 2002 | 09:49 PM
BitchinCamaro's Avatar
I used the bolts from SDPC, you can't reuse your old ones and the new ones are cheap, so why not get them?
Old Jan 22, 2002 | 12:13 PM
Earl 87gta's Avatar
I used a sset of arp bolt from a bolt kit I had it was like 70 for the hole kit they want 20 for 4 bolts.
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
Sanjay
Aug 12, 2015 03:41 PM
