72 vette w/91TPI to 94 LT1 swap
Old Jan 16, 2002 | 11:56 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
I have a 91 TPI system installed on my Stringray. What do I have to do to replace with a 94 Camaro LT1 intake? Will I see a performance improvement?
Old Jan 17, 2002 | 06:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You can either follow my tech article or send me your LT1 intake for me to mod. Either way it's an awsome mod for an engine that is suffering from the 4500rpm blues.
Old Jan 17, 2002 | 10:00 AM
Sauron91's Avatar
How much do you charge to mod a LT1 induction to fit an L98 5.7? ;> Also..where's that tech article?
Old Jan 17, 2002 | 10:58 AM
Engine: 4.0L
For $200 I will modify an intake you provide. That includes changing the
bolt pattern, distributor hole and spacer, clearance for the small
distributor, dual billet EGR block off plates, drilling/tapping for coolant
fittings(fittings included), and intake porting for a 58mm TB.
I can also supply the rubber fuel lines to adapt the LT1 intake to your
stock fuel system for an additional $80.
The tech article is at my web site. Here's a link to it direct.
http://members.home.net/millicanga/s...into_a_1st.htm
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
sreZ28
Aug 14, 2015 07:48 PM
