problem with bogging when cold
Old Jan 16, 2002 | 05:36 PM
caleb's Avatar
Car: 89' Iroc
i have a 305 TPI sitting in an 85' IROC, i swapped the prom for a JET stage 2 chip, and a 160 deg. thermostat, that was about a month ago, and lately i have noticed that when i drive my car after it has been sitting for a few hours, that it bogs whenever i touch the gas. could this be being caused because i unhooked the smog pump? could the chip and thermostat be causeing it? the car has about 150,000 and i was thinkin maybe i need new injectors? Ive only had the car about two months, i was reading that i should have done a tune up right after i got it, what things need to be changed? i flushed and chnged the rad fluid, changed the trani filter and fluid, the oil filter and fluid, and a new starter, what else should i change?
http://www.geocities.com/cibalibeb
thanks
Caleb
Old Jan 17, 2002 | 12:06 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'd go back to a 180 stat , change O2 sensor, plugs, cap& rotor, adjust TPS and IAC , time it, fuel filter, air filter, diff fluid , clean out TB with carb cleaner, send injectors to get cleaned.
Old Jan 17, 2002 | 12:19 AM
caleb's Avatar
Car: 89' Iroc
how do i set my TPS? what is the IAC? where is a good place to send the injectors too? the ones ive seen run $100-$125 for cleaning i can get a new set of injectors for $229 which is better? thanks i will change the thermo, the fluids and get back to u!
Caleb
Old Jan 17, 2002 | 12:38 PM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
Just a thought.
Check and make sure the cold start injector is still plugged into the harness.
Infested
May 22, 2018 11:56 PM
someone972
Aug 30, 2015 12:52 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
