TPI peak intake air pressure estimate?
Car: 1979 Corvette L82
Engine: Gen1 SBC 350 L82 4 bolt mains 010
Transmission: Monster 4L60e 2wd 1997 PWM capable
Axle/Gears: 355
I'm playing around with estimating my ignition system's energy and plug gap and Paschen's law that estimates the voltages required to jump a plug gap given a certain intake air pressure, compression ratio, and IAT values, I do NOT have a good value to enter for a typical "good" TPI intake's peak air pressure...
Anyone have some good TPI peak intake air pressure readings that they can share?
This page of the megasquirt manual includes a Paschen's law calculator: http://www.megamanual.com/seq/coils.htm
Ex: with a spark plug gap of 0.045", an intake air pressure of 101.3kPa, 10.2CR, and IATs of 35C (95F) it estimates 21k volts required to jump the gap (with a standard spark plug electrode and strap).
Adam
Adam
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: TPI peak intake air pressure estimate?
I mean, peak pressure for any n/a engine is going to be close to whatever the atmospheric pressure is at that elevation, right? Assuming TPI gets some dynamic charge due to its tuned-portiness, I can't imagine it going much over 115 kPa.
Axle/Gears: 355
The peak pressure is going to be around the torque peak and with a TPI intake we're tuning for the 3rd "harmonic" / reflected wave; I always hear that the "pulse strength" of the 3rd harmonic is +7% so does that mean I can just take the DA / current outside air pressure times 1.07 an use that to estimate the peak "intake pressure"? (I am thinking that would be "good enough".)
So let's say I get a high pressure, cold and dry (ok that part's not super likely) Seattle day and 15 PSI of outside air pressure, 15 PSI * 1.07 = 16.05 PSI or 110.6 kPA.
-That seems like a reasonable estimate.
I think actual cylinder pressure would be better and a formula that took into account VE would be more accurate (because with a good cam and a long-runner intake you're filling the cylinder quite a ways past BDC and > 110% VE is possible and the extra 10% is increasing pressure -so more like 16.5 PSI or 113.7 kPA.
-I'm just trying to get reasonable numbers. This is obviously just a thought experiment / bench validation of ignition requirements.
Adam
Axle/Gears: 355
So plugging the 113.7 kPA number into the Paschel's law calculator with a static CR of 10.2:1, and a cold for Seattle intake air temperature of 0 deg C / 32 F, I get 27.2kv required to jump even a 0.050" gap with a standard spark plug...
Spark really shouldn't be an issue at all for any decent coil even with a relatively large 0.050" gap; even a 0.060" gap should only require 31kV, so nothing to see here and I guess move on to worrying about something else...
Adam
Adam
Wishmaster's87IROC
Alternative Port EFI Intakes
Feb 16, 2008 11:12 PM
