Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
air intake? TPI system good or bad?
Old Feb 13, 2008 | 11:39 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
with my setup im just curious as to the air intake? Im currently using the stock TPI air intake system. Is that enough or not enough?
Is to much air a good thing? with my setup what should I be running?
thanks
Old Feb 14, 2008 | 09:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: air intake? TPI system good or bad?
i'm not sure on this one. I would think its alittle bit of a restriction just looking how the intake necks down over the radiator, even tho it widens, its still kinda small. i'm considering making a 3-3.5 inch CAI on my car
Old Feb 14, 2008 | 11:53 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Seeing as you are still running the MAF I would say no. The inside diameter of the MAF is smaller than your CAI. By the way what is your manifold pressure at wide open throttle and at rpm?
Old Feb 14, 2008 | 02:36 PM
how do I find out what the pressure is? will data logging show that?
Old Feb 14, 2008 | 05:38 PM
Car: 1989 GTA
Engine: 369 TPI
Yes, data logging will show it and that is how I get my information. That will tell you if you have a restriction between the airfilter and the plenum. If you do then you need to find out where the restriction is.
Old Feb 14, 2008 | 07:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I thought there was someone on TGO with a maf that had good results with a modified air box. Doc was his name i think. The stock box is a good design but becomes a restriction on larger/higher horsepower cid motors.
I modifed my airbox and boot. I replaced the stock boot with a 4" peice. I opened up the box as much as i could, and still have it fit under the hood.
I dont have any before and after numbers but it made a noticable improvement on my setup. Its Speed density so no maf. I would do it again.
Attached Thumbnails air intake? TPI system good or bad?-img_1710.jpg   air intake? TPI system good or bad?-img_1346.jpg   air intake? TPI system good or bad?-img_1417.jpg
Old Feb 14, 2008 | 09:23 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Mike H how did you go about opening it up?
Old Feb 14, 2008 | 10:36 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Here is a link to a thread about how to do it.
https://www.thirdgen.org/forums/tpi/...ied-there.html
Old Feb 16, 2008 | 11:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
MikeH, I think this link is the one with my pics of my Mega MAF.
https://www.thirdgen.org/forums/tpi/...stand-maf.html
For my MEGA MAF and airlid, I used 3.5" OD aluminum tubing and the appropriate rubber couplings. In the post above, I posted two pics, the first pic compares the MAFs, while the second pic conpares the airlids.
1992 Trans Am
May 10, 2023 07:19 PM
beachrodder
Aug 25, 2015 08:05 AM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
