Intermittent rpm drop at cold start
Old Jul 24, 2021 | 05:10 AM
KR81's Avatar
I found this thread from several years ago but like a lot of threads it was never resolved. I have a screen shot and a link to the thread, just want to get some info from anyone who can help as I very occasionally get this same issue where it starts strong at 1000rpms but will momentarily drop a few hundred rpms then rise back up and all is normal after that. Not a big deal just a little annoying and I'd like to try remedy it.
Mine is an 88 T/A 305tpi.
https://www.thirdgen.org/forums/tpi/628669-rough-cold-start-up.html
Old Jul 24, 2021 | 05:17 AM
KR81's Avatar
Re: Intermittent rpm drop at cold start
Iac is new and clean, tps is new and set to
.54, fuel pump and filter new, new fp regulator diaphragm, cold start injector seems to function fine, injectors were serviced and cleaned 6 months ago, if that all helps.
Old Jul 24, 2021 | 11:35 AM
Vader's Avatar
If you have the equipment to log data, it would be helpful. There are several routines which affect target idle RPM, and some which add IAC counts based upon time since start, and CTS and IAT inputs affecting the target RPM before the start timer has elapsed, Then there are adders which are consatantly active. Determining whether the IAC is tracking the target RPM or is being affected by adders could be a critical step in determining the reaon(s) for the phenomenon.
Old Jul 24, 2021 | 08:46 PM
KR81's Avatar
Thanks Vader. It is quite the phenomenon given its inconsistency and that it happened before I did a ton of work on the car late last year with the old parts and still does it with all the new parts.
I figured data logging would be my only real option, it's hard over here in Australia to get that done even at workshops that specialize in American cars. I'm hoping to pick up one of the old snap on scan tools on ebay from the us but I'm a bit hesitant cause they're still quite pricey and if it arrives over here and it's crap I'm out several hundred $$.
I have heard people mention an android based scan tool, do you know anything about them?
Old Jul 25, 2021 | 03:48 PM
Vader's Avatar
It is also possible to use TunerPro V5, Moates, EFI Live, or other applicatons to read ALDL date directly. I can understand that a used Modis (MT-2500) can be a risk, and may not reveal all the data you would like.
Old Jul 29, 2021 | 11:16 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Mine did this intermittently, was the computer temp sensor having issues (CTS). Swapped that, it's been fine so far.
Old Sep 2, 2021 | 01:48 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
I use this scan tool, can be found on ebay, and matched with aldldroid
Works pretty well!
Here's a screenshot of the data provided.
It can also be hooked up to tuner pro if you get the compatible model.
http://www.1320electronics.com/products.html
*Do disregard the data shown. This was from when I was ironing out some issues.
tpi84stepside
Oct 1, 2012 08:20 AM
wespeterow
Dec 7, 2004 06:21 PM
TheMysticWizard
Dec 11, 2003 09:05 PM
xformula79
Oct 12, 2002 01:44 PM
bigblue
Aug 30, 2002 09:05 PM
