cold start rpm flare
Old Dec 4, 2004 | 03:39 PM
wespeterow's Avatar
Car: 92 RS
Engine: 3.1 V6
Transmission: Manual
any ideas?... i have a 92 RS 3.1 V6....when i cold start the engine flares to around 2000 rpm (sometimes higher).
the idle speed gradually reduces, taking around 10 seconds to reach 1300 rpm.
replaced the IAC but no change.
Old Dec 4, 2004 | 04:12 PM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
Mine use to do that, until I replaced injector which was a couple days ago, Not sure if that what caused it, but I know it no longer does it
Old Dec 4, 2004 | 11:23 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Mine used to do that too. Right before the fuel pump went out in it. $$$ Hope thats not your case. Anyway, a dirty fuel filter could casue that. I've heard that a dirty throttle body/ICA can cause that as well. Try checking you fuel pressure at the shrader valve on your fuel rail.
~Max
Old Dec 5, 2004 | 10:18 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
by flares you mean it just runs at a high rpm? It's supposed to run higher when you start it cold to warm things up a bit then it'll reduce itself... Least I'm pretty sure it's supposed to run higher.
Old Dec 5, 2004 | 12:28 PM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
I think he means it revs up without him push the gas like he will be at 1500 or whatever and it will rev up to 2000
Old Dec 5, 2004 | 02:09 PM
92RSSlowmaro's Avatar
Right when you start the car? Mine does that too, its perfectly natural for the engine to idle high in closed loop operation; its trying to get to operating temp quickly.
Old Dec 7, 2004 | 06:21 PM
wespeterow's Avatar
Car: 92 RS
Engine: 3.1 V6
i think the cold start idle should be around 1300rpm. fuel filter is new, iac is new, throttle body cleaned, fuel pressure is 43psi engine off & 39 psi engine idling.... i'll check out the injectors. thanks.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
