Headers 1990 iroc z 305 tpi smog pump
Hey there you guys, I have a 1990 camaro iroc z with the 5.0 tpi. I bought headers off summit racing. I noticed on the stock headers there’s extra lines that go into the smog pump. So my questions are, if I remove those lines and delete the smog pump. Would I have to mess with the egr valve? I know they sell kits online with a plate to block it off. I seen a video of a guy on YouTube that does it but burns the chips. Can I remove the smog system without having to touch the egr valve? And having to tune the ecm? Nobody around where I live has a tune to burn chips anymore. Can you guys point me in the right direction? Thank you in advance.
Re: Headers 1990 iroc z 305 tpi smog pump
The Air Injection-Reaction (AIR) system is different from the Exhaust Gas Recirculation (EGR) system. The AIR system is really only active during cold starts and a WOT to dilute the exhaust with extra air. It really doesn't reduce power at all, but does clutter up the engine bay if not designed/installed properly. The AIR can be removed, but if you are subject to a vehicle emission inspection, it will probably fail. Removal may also require reprogramming on later vehicles, but not ThirdGen F-Bodies as far as I know.
The EGR is only active when at part-throttle cruise, and also does not reduce power at all. However, it does lower combustion chamber temperatures and allows for greater timing advance at part-throttle cruise operation (most of your highway driving). Removal of the EGR will certainly require reprogramming.
Car: 1987 iroc convertible
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
If you install headers, can you just block off the lines coming off the exhaust manifolds? Or will this create other problems?
