TPI idles between 2k-3k?! How do I fix?
Old Aug 31, 2021 | 11:23 AM
MarksmanB's Avatar
Car: 1990 firebird formula hard top WS6
Engine: L98 5.7L MFI 350 sbc tpi
Transmission: Borg Warner world class T5
Hello. I am now to this sit and still trying to figure it out. I used the search engine on ThirdGen.org but I couldn't find anything similar to my problem, I just get irrelevant results.
Anyways, I have a 1990 firebird formula 350 TPI and it is idling super high. It likes to stay at 2,000-3,000 rpms and will not go down to 750 rpms like its supposed to even when I push the throttle control on the throttle body. Any suggestions on how to fix this? I've tried the idle adjustment screw but it didn't help much. The car drives perfectly fine so I don't think it's out of time or anything. Thanks in advance!
Old Aug 31, 2021 | 11:40 AM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: TPI idles between 2k-3k?! How do I fix?
You must have a large vacuum leak somewhere past your throttle body. The engine should not be able to get enough air to rev that high with the throttle blades closed
Old Aug 31, 2021 | 06:48 PM
MarksmanB's Avatar
thanks for your response. I will check again for a vacuum leak. Do you think the Idle Air Control valve could be bad?
Old Aug 31, 2021 | 08:44 PM
Vader's Avatar
It is also important to use a diagnostic tachometer for any such work, and not rely on the in-dash tachometer looking thing, which is more a part of an accessory trim package than any kind of actual instrument. Those trim pieces are notoriously inaccurate.
Old Aug 31, 2021 | 11:38 PM
MarksmanB's Avatar
haha well my car is straight piped so I hear the engine roaring at a stop light. My tachometer works just fine. Anyways I took a look at it and I ended up haven’t a big crack (more like a missing chunk) in one of the intake gaskets. So I replaced it and it works good now
Old Sep 1, 2021 | 12:54 AM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
One guestion. Does it sound like the engine is at 2000 RPM? I only ask because when my tach started to fail, it started claiming that I was idling at 2000-3000 RPM and was cruising at 5000+.
I did freak out because my engine was kind of loud but I replaced tachs and it turns out I was idling at 1000 due to a vacuum leak. Just a thought.
TA<3er4Life
Nov 26, 2012 01:19 PM
karl's-92'-z28
May 6, 2011 09:05 AM
PontiacMC
Sep 17, 2010 10:28 PM
88formula305tpi
Apr 10, 2010 02:14 AM
knightrider91
Aug 20, 2008 01:11 PM
