Does Anyone Have the Part Number for the MAF Relays and Fuel Pump Relays
Old Oct 22, 2021 | 07:41 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
As well as the Pigtails? When I search two relays come up a 30 Amp and a 20 Amp. Which one should I use? Also I can't find the pigtails at all. My car is a 1986 Camaro IROC Z. I know later years used a different shaped MAF relay but mine uses the rectangle shaped one. My wiring on my pigtails is really bad and I would like to replace them ASAP. Here are some pictures if anyone can make out the part numbers and see how bad my wiring is:
MAF Power Relay
Not sure
Bad wiring
Closest to Engine Block.
Old Oct 24, 2021 | 05:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Does Anyone Have the Part Number for the MAF Relays and Fuel Pump Relays
GM 10067925 MAF
GM 10094701 MAF BURN OFF
GM 1407814 FUEL PUMP\
You can use the burn off relay for the fuel pump relay and vise versa
Old Oct 24, 2021 | 08:19 PM
Engine: LB9 305 TPI
Originally Posted by mantaguy
GM 10067925 MAF
Thank you. According to Rock Auto, the 30 Amp relay is the MAF Power Relay.
However, I can't find the Burn Off or Fuel Pump save for old eBay listings. Are the Fuel/Burn Off relays the 20 AMP from O'Reillys?
Old Oct 27, 2021 | 02:30 PM
Engine: LB9 305 TPI
Ok so I replayed the MAF Power Relay with part RY31. It's the 30 Amp relay. It seemed to make a huge difference. The rough idle at start up and when braking is gone.
Now I'm not sure which part is MAF Burnoff/Fuel Pump relay. Maybe I'll be that 20 Amp relay and see if works. Does anyone know what relay you used recently, since the park numbers no longer work.
Old Oct 27, 2021 | 07:00 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Have you tried TPIparts.net? They may still have the relays.
Fred
Old Oct 27, 2021 | 08:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
on the 86 Trans Am the fuel pump relay was in the center of the three relays,the burn off was to the left of it and the MAF was to the right of it
Old Oct 27, 2021 | 10:21 PM
Engine: LB9 305 TPI
I know where they are. I already replaced the MAF Power relay. I just can't find a Burnoff or Fuel Pump relay. None of the major auto parts stores seem to have it and Googling the above part numbers only gets old eBay listings or old forum pages from the 2000s.
Old Oct 27, 2021 | 10:23 PM
Engine: LB9 305 TPI
Fred
Good news is they have the pigtails bad news is no relays.
Old Oct 27, 2021 | 11:31 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Rockauto has relays that look the same listed under Fuel Pump / Circuit Opening Relay:
WVE 1R1240 and Standard Motor Products RY121.
Might want to confirm those are for your year.
Old Oct 28, 2021 | 07:01 AM
Engine: LB9 305 TPI
I think WVE 1R1240 is the right part. I'm going to order 2 of them.
Old Oct 28, 2021 | 07:31 AM
stron3's Avatar
Car: 87 Camaro Z28
I just finished splicing the pigtails that I got from TPIparts. Quality stuff, I highly recommend. I replaced the relays with NOS stuff (made in USA) I found on eBay, I'm not sure about the China stuff but it may be just fine.
Old Oct 28, 2021 | 07:34 AM
Engine: LB9 305 TPI
Awesome. I'm going to order those this weekend.
Old Oct 28, 2021 | 01:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Oct 28, 2021 | 01:55 PM
Engine: Lb9
Transmission: M20
You can update to weatherpak relays and pigtails lookup 89 Vette or f body.
Old Apr 5, 2025 | 04:03 AM
Derrick J's Avatar
MAF Power Relay
Not sure
Bad wiring
The part number I do believe is 18987625 but I can't be for sure anyway try that hopefully it will help you
elcam84
Nov 3, 2024 02:07 PM
Sean White
Apr 29, 2021 07:20 PM
Luva350
Nov 16, 2002 02:09 AM
rezinn
Jun 10, 2001 01:27 PM
