A little science behind TPI
Old Nov 5, 2021 | 03:32 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Was studying variable intake manifolds and ran across this, the first section explain a lot about why the TPI excels in the low RPM range.
https://www.autozine.org/technical_s...e_exhaust.html
Old Nov 7, 2021 | 03:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: A little science behind TPI
@sofakingdom recently made a great post on this that I'm copying here,
https://www.thirdgen.org/forums/tech...mitations.html
TPI stands for Tuned Port Injection.
THIMK about the concept of "tuned" for a moment. That term implies that, at some certain frequency or frequencies, something happens that's different from what happens at other frequencies.
Let that idea sink in.
Now: the speed of sound in air at STP (standard temperature and pressure: about 760mm or 30" of pressure, aka 1 atmosphere, and 0°C or 32°F, aka freezing of pure water) is right around 1100 feet per second.
That means, if you have a tube (something like, let's say, a musical instrument), that the "note" it produces, which is controlled by the frequency at which the length of the tubing it's made out of has a resonance, is related to its length. Pretty basic stuff really.
In any engine, the air rushing down the intake tract, will slam into the back of the intake valve, just as it closes, producing a pulse of significant POSITIVE pressure. All intakes on all engines do this of course, but in a general way, it's not often used as a direct method of augmenting cylinder fill (power output), in anything resembling a "street stock" sort of application.
TPI however took advantage of this fact of physics. It is designed such that the pulse of positive pressure from ONE cylinder travels BACK UP the intake tube (which is about 22" long), into the plenum, and then down into ALL THE OTHER intake tubes. Let's keep the numbers nice and round: let's say that the sum of the 22" up the one tube, plus the 22" down the other tube, plus the length rattling around in the plenum, is 48", on average. That's 4'. TPI uses this reflected pulse to AUGMENT the fill of the NEXT firling cylinder, but only at some RPM at which the pulse arrives at the next cylinder after it has travelled about 4'.
Butt, the pressure in the intake tract is somewhat less than atmospheric, otherwise the air wouldn't be motivated to go down it. The speed of sound is somewhat less when the pressure is lower. Once again. to keep the numbers REAL SIMPLE, let's simplify the speed of sound inside a running engine's intake manifold, to 1000' per second.
What this means then, is that at some engine RPM at which the POSITIVE PRESSURE pulse generated by the sudden closing of the intake valve while air is rushing down the tube and SLAMS into the back of that valve, and then that pulse bounces back from that valve and finds its way to some OTHER intake valve that happens to be OPEN at the moment, would result in GREATER cylinder fill (torque, aka output) than would happen at ANY OTHER engine RPM. By selecting that length - 4' - we have TUNED the engine's intake tract to REINFORCE cylinder fill at some particular RPM, or more accurately in some range centered on that RPM, that corresponds to the time it takes for sound to travel 4'.
RPM is a count of events per minute; "frequency" is usually considered in terms of events per second; so all we have to do to convert from one to the other, is to apply a conversion factor of 60. Trivial to say the least.
Make sense so far?
All that remains then, is to find this RPM. So: the time it takes for sound to travel 4', is 1000 ÷ 4. How convenient: that's exactly 4 milliseconds, or, 1/256 of a second. What RPM is that?
Well, a V8 engine fires 4 of its cylinders per revolution. That means that the RPM at which the cylinders are firing exactly 4 milliseconds apart is the RPM at which it make one full revolution in 16 milliseconds. What RPM is that? 1 second ÷ .016 = 62.5; again, let's simplify it so the numbers come out even (which happens to take out some of the error of the last simplification), and call it an even 60. 60 revolutions per second is ... 3600 revolutions per minute. 3600 RPM. Let THAT number sink in.
TPI is carefully, rigorously, mathematically designed, according to well and widely proven and demonstrated principles of physics, to produce its optimum torque at 3600 RPM.
Now: did you notice ANYTHING about a real-world engine that was CONSPICUOUSLY ABSENT from all of these calculations? I certainly hope so.
The thing that is COMPLETELY missing is CUBIC INCHES.
What does this tell you? Basically, that NO MATTER WHAT SIZE the engine you put TPI on is, its peak torque is going to occur at 3600 RPM. Doesn't matter how large the tubes are; doesn't matter what cam you put in it; doesn't matter what the head flow is; doesn't matter what the throttle body diameter is; 3600 RPM. It's DOMINATED by the properties of those tubes on the intake. The best you can do is to make sure that the engine is as restriction-free as you can get it, at 3600 RPM; and that the cam you select produces the largest possible pulse of "reversion" pressure at ... 3600 RPM. Which is why TPI is SO PICKY about cam selection. Just jamming a bigger cam under it will often make it produce LESS power, if said cam doesn't agree with TPI's ... 3600 RPM ... constraint.
OK, so once again, lets go back to numbers. (after all, everything in life is numbers, whether you humans are willing to admit it or not) Power, whether measured in HP, kW, or whatever, is the time rate of the production (or expenditure, depending on which way you're looking at it from) of energy. X number of units of energy per Y units of time, in all cases. So how do we get from torque (work, or energy), to power?
1 HP = 33,000 lbs of weight lifted 1 foot in 1 minute. Pretty simple really.
Back in the 1700s, when steam engines were replacing horses, the single biggest use of such a thing was pumping water out of coal mines. (coal being the fuel that powered the early Industrial Revolution worldwide, but particularly in England and Germany) Everybody that built engines, was charging people that used them, according to how many horses their engine could replace. Well, how do you put a number on that? They would look at a horse walking around a turnstile sort of thing that was connected to a pump shaft, and taking into account how long the horse would live depending on how hard you worked it, they would figure out how much water the horse could lift in some unit of time, without working it to death. Believe it or not, people all over the industrializing world all seemed to come up with pretty similar numbers. Turns out, d00d named James Watt (ever heard of a unit of power called the watt?) in England, determined that one horse, under conditions that the horse could sustain more or less indefinitely (over a normal horse lifetime anyway), could lift 33,000 lbs of water 1 foot out of a coal mine, every minute; and could do this more or less all day, every day, day in and day out, from attaining full growth to visiting the knacker. That's one horsepower then: 33,000 lbs, 1 foot, 1 minute. In Germany, whoever made the same calculation there, came up with a number that was closer to 31,000 lbs. (maybe Germans didn't work their horses as hard? maybe theirs weren't as big or as powerful? maybe they didn't feed them as much or as well? iunno) Keep in mind this was all going on before the metric system was invented in France during the French Revolution, as some kind of pure scientific measurement method devoid of any religious or historical taint. (read about the French Revolution: you'll be simultaneously inspired and horrified, it was a time when things got tried that couldn't possibly ever be tried again under any other circumstances, even besides the guillotine)
Torque is a twisting force. 1 ft-lb is the amount of twisting that occurs when one pound of force is applied (or expended) on a rotating object 1 foot in radius (2 feet diameter) that applies 1 pound of force at its circumference. Think, a tire being spun, pushing a car. A point on a rotating thing with a 1 foot radius moves 2 pi feet in one revolution.
So do we get from torque, to horsepower?
Well, if horsepower is the time rate of doing work, and something that has 1 ft-lb of torque does 2 pi of work every time it rotates, then all it takes is another conversion factor. 33,000 ÷ (2 pi), or 5252.11, is this new Magic Number. Often referred to on dyno pulls as 5250 RPM, where the torque and HP curves intersect, if plotted on the same axis. Horsepower (at any given RPM) = the torque at that RPM, times the RPM, divided by 5252.11. Simple: it's all numbers.
A typical real-world engine like ours, capable of running on fuel we can actually buy at the street corner, under conditions we actually can run the engine under, can produce about 1¼ ft-lbs of torque per cubic inch, at whatever RPM it produces its peak torque at. You can move that RPM up or down by selection of cam, intake, exhaust, etc.; but in the end, it's still 1¼ ft-lbs of torque per CI. Therefore a 305 can produce roughly 380 ft-lbs max, a 350 about 440 ft-lbs, and a 400 about 500 ft-lbs. Butt, don't forget, you're working with TPI: by definition torque peaks at 3600 RPM. So if you have a 305, your HP will be around 265. All you have to do to find the horsepower you're going to make (assuming you've optimized everything... it's all downhill from the number this calculation gives you, in the RW) is plug your CID into that simple equation.
400 CID × 1.25 = 500 ft-lbs. If that occurs at 3600 RPM, then your HP will be 500 × 3600 ÷ 5252.11; or, around 340 HP. For a 350, you're going to get real close to 300 HP.
BUTT: that whole "reinforcement" thing comes with a penalty. And that is, at any HIGHER RPM than 3600, the pulse provides less and less reinforcement, which means the help it gives you is less and less (the torque falls off REAL FAST as RPM increases); and, worst of all, at SOME RPM, the pulse actually begins to INTERFERE with cylinder fill. It REDUCES engine output BELOW what it would be WITHOUT the tuned effect at all. And THAT RPM is real close to 1.5 times the peak RPM; or, 4500. What you get is the classic "Mt Everest" TPI torque curve: MASSIVE peak at 3600, craters above 4000, is ALL DONE by 4500.
Real simple. It's all numbers.
Old Nov 11, 2021 | 01:51 PM
BadSS's Avatar
I think it's important to point out the calculation Sofa provided is the resonance frequency of the runner length that gives a targeted peak, “tuned” effect occurring at 3,600 RPM. As Sofa pointed out diameter and other engine factors does not affect resonance tuning. However, it is not a limitation or ceiling to peak torque – peak torque is dictated by other factors than just the intake’s resonance or “tuned” RPM.
I do absolutely agree that GM meticulously designed the stock TPI's runner length, diameter, and other engine factors around the resonate frequency to provide peak torque at 3,600 RPM. You can see this when using engine simulation software or by plugging the numbers from a stock TPI into the Wallace Racing "Intake Runner and Peak Torque Calculator" below.
http://www.wallaceracing.com/runnertorquecalc.php
When you plug in the area of the stock TPI runner, which is 1.81” based on the runner’s inside diameter of 1.52”, and use 350 as the engine displacement, you get peak torque at 3,649 RPM. That combined with the tuned runner length, stock small port low-flow heads, and the small cam, gives a compounding or stacking affect around 3,600 RPM. This is why the stock TPI has trouble making power over 4,500 rpm and drops off the proverbial cliff – not because of just the intake tract length.
If you look at the old Ten Times the Torque, EFI intake shootout article they tested a stock TPI on a fairly healthy 383 with a big cam capable of making 500 HP with a short runner intake. Below is a to-scale overlay from that article of the stock TPI, a large tube runner TPI (same runner length as stock), and a MiniRam, which has such a short runner length there is no tuned effect present.
Torque for the stock TPI peaked around 3,800-3,900 RPM, the TPiS large tube runners peaked at 4,000 RPM, and the MiniRam peaked at 5,000. Note the red circle where it shows torque for the large runner TPI is the same as the MiniRam at 5,000. This is somewhat coincidental, but only possible because of the increase in the intake tract area. Also note that while torque falls off fairly quickly due to the runner length of both TPI systems, horsepower stays flat past peak as opposed to dropping like a rock in a typical TPI build - this is because of the larger heads and cam used. The increase in the stock TPI runner diameter from 1.52” to approximately 1.625” (along with the increase in area for the rest of the intake tract) was worth about 40HP and power throughout the entire pull.
Here’s another example of a TPI with a measured runner tract of 21” (about the same as a stock TPI) with 2" diameter runners (1.875" ID) on a health 369 (4.060" bore and a 3.562" stroke). Peak torque is around 420 at 4,300 RPM and peak HP is around 420 at 6,400 RPM – rear wheel through a 4L60E. Here’s the link to the specifics and science used behind this non-typical TPI build for those that might be interested.
https://www.speed-talk.com/forum/vie...404827#p404827
Old Nov 13, 2021 | 10:21 AM
LiquidBlue's Avatar
Transmission: MD8
wow, thanks guys. the more I read, the more I realize I don't know!
Old Mar 27, 2022 | 10:34 AM
LiquidBlue's Avatar
Transmission: MD8
I'm working thru an issue with my 545 right now, requires pulling the intake out. thought I'd show it here. this is a continuously variable version of a TPI (more or less). it changes the length of the runners based on engine conditions so there torque curve is essentially smooth and never ends. this thing is a monster, in the back of which you can't see here is a solenoid that adjusts the tube lengths. pretty amazing technology to put into mass production for 2004. the problem with it was it was so big, it wont fit in many cars. another solution had to be found.
TXFBODYGUY
Sep 15, 2009 01:41 AM
