What are corvette vs. camaro TPI differences?
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I was wondering if the corvette tuned port injection was different in some way than in a 350 camaro tpi.
Speed
Speed
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
they had an external EGR becasue of the aluminum heads not haveing a crossover . . Other than that they had a metal distributor cover and a little different tune .
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Corvette had a better exhaust system with true duals but besides aluminum heads, external EGR and a different tune. They are basically the same.
Car: 1992 Camaro RS
Transmission: 4L60
yup all the same. The manifold base was slightly different to use the external EGR tube and the center 4 manifold bolts were the older style.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The fuel fittings from fuel rail comes out on opposite side also. I think the plenum has a fewer groves cut in top also.
Car: 1989 IROC-Z
depends on what year it was
I'm using a corvette setup. The fuel rails sometimes dumped on the passenger side instead of curving over to the driver's side. Also, as mentioned, there may be an EGR port on the passenger's side just in front of the distributor hole. You can buy block-off plates to cover that up... I made one by using the corvette EGR tube, removing the tube and welding the hole shut with a small piece of steel.
The other thing to consider is the ECU. Some computers on corvettes were the 1227727 (weather proof) design (speed density), where the corresponding 3rd gen used the 1227730 computer. They don't have the same connectors, but they use the exact same program, logic and prom. Also, this type of harness, if you're swapping is shorter because the ecu was typically kept in the engine compartment. So, if you use that for a swap, you too will probably have to mount the ecu into the engine compartment.
no true duals on L98 vette's. there exhaust sucked as well.
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Originally Posted by speedmachine
Hello
Speed
Speed
I posted this somewhere else...
There were three different plenums used through the TPI era-
The plenums break down into three groups--'85-88 (left), '89 only (middle), and '90-up (right).
The fuel inlets and returns differ between the different years. The '89-91 Corvette fuel rail (left) has a female 16mm passenger-side inlet and a female 16mm return. The '85-88 Corvette (middle) has a female 16mm passenger-side inlet and a female 14mm return. The '85-92 F-body (right) has a female 16mm driver-side inlet and a female 14mm return
Three intake manifold styles were used on the TPI equipped engines. The '87-91 Corvette intake on the left used a heat-riser tube off of the passenger-side header and has a water crossover at the back to relieve hot spots on the back of the aluminum heads. The middle intake was used on '85-86 IROCs, T/As, and Corvettes with cast-iron heads with outside valve-cover bolt holes (early-style). (The two center bolts on these two intakes are at the same position as the end bolts and will fit the early head-bolt pattern.) The intake on the right was used on '87-92 IROCs and T/As with cast-iron heads with center-bolt valve covers. The '87-95 intakes with the later cast-iron head-bolt pattern can be machined to fit the early bolt pattern. If you want to run Vortec and Fast Burn-style heads, GM and S&P have new TPI intakes to adapt a TPI to both.
All the passenger-side TPI tubes (top) for all '85-92 models are the same. There are two different driver-side tubes. The '85-88 units (left) had the ninth injector port (arrow), while the '89-92 F-body and '89-91 Corvette tubes (right) didn't.
Identifying GM's Tuned-Port Injection Units-
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
"Some computers on corvettes were the 1227727 (weather proof) design (speed density), where the corresponding 3rd gen used the 1227730 computer. They don't have the same connectors, but they use the exact same program, logic and prom."
ALL Vette SD ECM s are 727 weatherpack.
The Vette 727 ECM programming has a requirement for a data signal from the CCM (another damm computer ) which is not present in the F-bodies.
727 popular with offroader using EFI due to it's waterproof ability
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
Re: What are corvette vs. camaro TPI differences?
What has to be done to the 87-92 camaro intakes to fit the 88 style aluminum corvette heads,I had no idea their was a difference in the intakes.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
If you're thinking about using this setup on an emission controlled vehicle, make sure it's a legal transplant, because here in California, I believe only F-Body setups can be transplanted to other F-bodys...
Car: 91 camaro vert
I'm not to worried about emissions, i have a 91 305 tpi and im swapping in a 350 with aluminum vette heads not sure what machining needs to be done hope its not too difficult.I haven't had time to check out the differences on my parts yet.
Iroc8t8
May 4, 2026 08:09 PM
kah992
Aug 19, 2015 02:55 PM
