Adjustable Fuel Regulator TPI Kit Source/Install
Old Mar 11, 2022 | 12:23 PM
R3500's Avatar
Have a TPI setup in my work truck and need to install a new fuel pressure regulator.
Who makes a kit to convert the OEM regulator? Stock or adjustable fuel pressure is OK.
Looks like I'll need to remove the upper plenum to install it correct?
Old Mar 11, 2022 | 01:32 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Adjustable Fuel Regulator TPI Kit Source/Install
I like the Holley one because you can adjust it without tools with the car fully assembled. You will need to take off at least the plenum, maybe the runners. It's a very good time to ensure the EGR valve is operational, as well.
Old Mar 11, 2022 | 04:27 PM
R3500's Avatar
OK thanks...I located an Accel APR that I had in my parts bins! Now need to keep my eyes open for another one for an upcoming project.
Old Mar 16, 2022 | 03:46 PM
Eightyninef's Avatar
How do you test the EGR valve ?
Old Mar 16, 2022 | 05:15 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Suck / blow into it and see if it does the thing and holds pressure. Mine fell apart as soon as I touched it, but it would also not hold pressure.
jonarotz
Dec 30, 2008 06:17 PM
BADMAN
Nov 1, 2006 01:41 PM
Cdn Chopper
Jul 30, 2005 03:46 PM
puckyou
Sep 10, 2003 01:26 AM
