No Spark
Old Jul 26, 2022 | 10:40 PM
Eightyninef's Avatar
No Spark
1989 TPI, All stock. No spark. Changed the ignition module, cap & rotor. Still no spark. What else would cause no spark?
How do I test the coil ??
Old Jul 28, 2022 | 08:27 AM
Vader's Avatar
Re: No Spark
Resistance testing the primary and secondary windings would be a good beginning. If injectors are not pulsing that would indicate no signal from the pickup coil, and that would also keep the ESC from firing the ignition.
Old Jul 28, 2022 | 09:18 AM
ULTM8Z's Avatar
Re: No Spark
Also make sure you're getting 12V to the coil while cranking.
Old Jul 28, 2022 | 09:36 AM
89GTA GUY's Avatar
Car: '89 GTA
Engine: 5.7L 350
Re: No Spark
Have you checked your spark plugs and wires?
Old Jul 28, 2022 | 04:32 PM
Re: No Spark
It's upstream of the wires & plugs. It's a no spark issue from the distributor or coil.
Old Jul 28, 2022 | 04:36 PM
Re: No Spark
No gas in the oil, no gas out the exhaust. But 45PSI at the rail. So I'm assuming injectors are not pulsing, or I would smell fuel somewhere.
Are you telling me I'm pulling the distributor?
80,000 miles, but there are constantly rust particles under the cap & rotor area. For years I have no idea where these particles are coming from.
Old Sep 9, 2022 | 09:39 PM
Re: No Spark
This problem was caused by a bad pickup coil. Rusted .. corroded along with the stator being worn out.
poizonpyo
Mar 28, 2019 04:14 PM
mynameisfrank89
Sep 26, 2016 07:59 PM
Ricke115
Jul 14, 2011 12:36 PM
jaysfs
Aug 27, 2006 03:08 PM
Balael6
Aug 7, 2005 08:56 PM
