Need advice on a TPI build
Old Sep 24, 2022 | 01:10 PM
Fly Skids Up!'s Avatar
Hi, I need advice on a TPI build. Being this is my first post here let me introduce myself. My name is Marc and I'm a retired truck mechanic with a 1982 Corvette with the crossfire injection/700r4 . My Car is mostly stock with just headers, a Magnaflow cat and a 16146299 ECM with my own tune. With the 2.87 rear my best time with the car was14.9@90mph. Since then I have changed the rear to a 3.07. I'm looking for a TPI build that will give me a 14.00@100mph. So here's what I'm thinking. A TPI setup (already have with 22 lbs injectors), Flotek 180cc heads, Comp cam 8-408-8 206/212 duration .480/.487 lift 110 lobe separation, a rebuilt L31 short block, and dual cat's. I've ran all this through Desktop dyno 5 and it claims with headers and open exhaust 329HP@4500rpm with a average HP of 265 between 1500 to 5000rpm. Is 110 lobe separation to narrow for a speed density EFI? Are Flotek 180cc good or should I go with something else? Thanks, Marc
Old Sep 26, 2022 | 07:13 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Need advice on a TPI build
Stock L98 with a few bolt ons should get you 14.0 so certainly your setup should surpass that.
Old Sep 26, 2022 | 11:56 AM
I'm just was concerned about the 110 lobe separation and being not computer compatible where the same cam with a 112 lobe separation is. However the 110 makes more power in the region that the TPI likes. I'm new to all this stuff, building a modded engine and ECM programming. When I wired in the 16146299 ECM from a 92 5.7 Tbi truck it ran very rich at idle. I'm guessing that the more aggressive crossfire cam was singling the ECM for more fuel. I burned my own chip and reduced the amount of fuel in that region. With that said I saw a few post down that FiTech is coming out with a complete plug and play system for the TPI. I didn't know that such a thing existed. I think I may just go that route. Thanks, Marc
johnnyph1
Nov 11, 2022 07:27 PM
gold_81_camaro
Sep 16, 2011 12:29 AM
nomad88z
Oct 31, 2007 12:41 AM
Tibo
Nov 18, 2003 07:37 PM
Proximo
Mar 8, 2003 03:57 AM
