Sequential paired injectors
Old Nov 4, 2022 | 05:29 PM
Tim Newton's Avatar
Car: Corvette 1958
Engine: GM LB9 TPI 1985
Transmission: TH700R4
1985 TPI replacing my old batch-fire ECU with a Haltech Elite 750 with 6 injector outputs. I can can leave as batch-fire or set up as semi-sequential by pairing injectors.
I need advice on what cylinders should be paired, and is it necessary to completely rewire the electrical loom for pairing.
Also, will I need to change or add any engine sensors such as a camshaft position sensor or crank position sensor if sequential injection is set up.
Old Nov 13, 2022 | 07:52 AM
Vader's Avatar
Re: Sequential paired injectors
With only 6 injector drivers, I can't see a good way to pair injectors, and anything you attempt is probably going to be functionally no better than splitting them into two banks,
jcp74
May 2, 2008 08:29 PM
wrapper8758
Jul 31, 2007 07:46 AM
marko82
Jul 16, 2005 01:44 PM
rgchild
Mar 30, 2004 12:16 AM
