Afpr vacuum location
Old Nov 12, 2022 | 02:30 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
So I placed the vacuum port on afpr facing passenger side then realized the stock location is facing more toward firewall. Think it matters? I would normally just adjust but those damn safety torx are fragile( and unavailable), so I would rather leave it in that position if the consensus is that it does not matter. Thoughts???
Old Nov 13, 2022 | 07:49 AM
Vader's Avatar
Re: Afpr vacuum location
If you can get a vacuum hose onto the FPR nipple, it just doesn't matter. A 90° rubber elbow on the end of a hose is not considered cheating.
Also, the next time you assemble one, consider applying anti-seize compound to the threads of the security Torx screws to allow a better chance of removal in the future.
Old Nov 13, 2022 | 08:21 AM
Engine: 5.7 l98
Ok, I didn't think it matters, but wanted to get opinions considering it is related to fuel. Thanks
87iroz-c
May 14, 2021 03:36 AM
AKATDOG
Apr 24, 2009 10:08 AM
rockmebaby
Carburetors
Jun 8, 2004 11:24 AM
jfreeman74
Jan 18, 2003 05:44 AM
