Fuel pump ? Or replace the whole assembly ?
Old May 22, 2023 | 09:08 PM
murphymckenna's Avatar
Car: 1986 Camaro Z28 Iroc-z
Hi thridgen ! I have a doosy of a question, should I replace the fuel pump assembly since I'm already down there ? Or just the fuel pump and screen filter ? Also if you guys think I should change the assembly can you help me find the right one ? Don't want to get scammed or buy crappy stuff 😒
Old May 23, 2023 | 06:21 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
Re: Fuel pump ? Or replace the whole assembly ?
you should inspect the condition of your fuel-level sending unit. if you have really crappy gas or have been using octane boost, you might need to replace that too. otherwise just replace the pump and the sock, the stuff that comes in the kit.
Old May 23, 2023 | 05:04 PM
Thank you sir, I ordered one either way even if I don't have to replace it just incase there's a problem
patricklav
Carburetors
Mar 26, 2012 02:42 PM
White93z34
Aug 7, 2005 11:53 AM
