Question on Idle Speed vs Temp Table
Old Jul 15, 2023 | 05:21 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I have a question concerning the Idle Speed vs Coolant Temp table in the ARAP Bin. Is the idle speed in the table with the trans in Park/Neutral or with the trans in Drive and vehicle stopped/not moving?
I have a 350 with modifed TPI running ARAP bin. I'm not having any issues, but I was curious about this table.
Old Jul 15, 2023 | 05:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Question on Idle Speed vs Temp Table
There is a p/n adder table
Old Jul 15, 2023 | 06:14 PM
Fred SS's Avatar
Transmission: 2004r
I have seen the P/N rpm adder table. So, the Idle Speed vs Coolant Temp table is with the trans in Drive. In P/N, it adds rpm via the P/N adder table. My TPI motor idles around 900 rpm with the trans in park. I just removed my BBK 52mm throttle body and installed the polished throttle body I got from Dr. Injector a few years ago. I still need to adjust min air. I was hoping to not have to do that, but at idle my IAC counts were close to 60. From what I have read on these forums, 60 counts at idle is way too high, so I need to open the throttle blades more.
Last edited by Fred SS; Jul 16, 2023 at 10:54 AM. Reason: Changed "trans in Park" to "trans in drive"
MikeT 88IROC350
Jul 9, 2022 09:16 AM
92Z
Jul 18, 2013 04:50 PM
thebruce
May 31, 2009 02:23 PM
dan_t
Jun 30, 2008 07:08 AM
2new2funny
May 29, 2005 02:05 PM
