discrepancy-desired idle speed vs. setting in bin
Old May 27, 2005 | 10:36 PM
2new2funny's Avatar
Just wondering why I set the"idle vs. coolant" to 675 rpm and, when datalogging, the ALDL Values screen in TunerPro shows the "desired idle speed to be 725 and, yes, it idles at 725. (MAF 6E mask)
Any ideas?
Old May 27, 2005 | 11:39 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Not positive on the $6E but on $8D the Idle Vs Coolant is only active "in gear".
there are adders to that value when NOT in gear that cause it to raise up.
Old May 28, 2005 | 09:05 AM
2new2funny's Avatar
I'll have to check that out. It could possibly be just a "park" thing. It was getting late...
Old May 28, 2005 | 10:13 AM
JPrevost's Avatar
Car: 91 Red Sled
"Idle speed adder park/neutral" that is 50rpm in the ARAP bin. 675+50 = 725
In TunerPro, use the Ctrl + F feature to find items with the word "idle", it helps!
Old May 28, 2005 | 10:55 AM
2new2funny's Avatar
Exactly.
As soon as I left the keyboard, my "mathematical" mind started working too!
Thanks.
Old May 29, 2005 | 07:55 AM
Steven89Iroc's Avatar
On a related note, in an $8D that was originally an LB9 car but has an L98 bin with a manual tranny, does it think it's in park or in gear (being that there were no provisions for a switch)?
Old May 29, 2005 | 08:50 AM
JP86SS's Avatar
I would "guess" that there was a switch on the clutch pedal instead of the automatics Neutral safety switch.
The ECM input indicates NEUTRAL/PARK so anything else would be in gear.
Old May 29, 2005 | 10:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In this case the prk/neut input is left open. The ECM sees the transmission as 'in gear' all of the time.
RBob.
Old May 29, 2005 | 02:05 PM
Okay, thanks. I was wondering because I can't get it to idle steady (as it did with the LB9 bin), but this doesn't really help me figure it out I guess.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
