87 camaro with super ram idle problem
Old Aug 10, 2023 | 10:15 AM
Supergt1999's Avatar
ive got this car running decent but the idle is erratic and stalls. ive changed and clean the IAC,TPS,O2 sensor,temp sensor, and new MAF. i pulled the super ram off and resealed it because i found some vacuum leaks, and it got better. but still the idle is erratic and stalling. yesterday i rigged up a way to pressure test and there seems to be a leak at the throttle body shaft near the return spring. how much air should be able to leak from this? i was using 15psi of air but could not get more than 6psi into the intake due to the leak? im wondering if this is my idle issue?
tognabologna87
Mar 24, 2016 04:41 AM
thegoochking
Jan 19, 2011 07:38 PM
ken3983
Jul 5, 2007 09:18 AM
DustyJL
Jun 20, 2006 06:39 PM
89Irocz23
Aug 15, 2001 08:43 PM
