RAM Air effecting idle??
Old Jun 20, 2006 | 12:06 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
I built some ram air scoops and ever sense I built them my car doesn't want to idle when it is warmed up. When the car is cold it is runs/idles fine. Once its warmed up it wants to idle around 2,000 and when i go to brake, the idle is lowered below 2,000 and the car runs like **** and throws code 33(low vacuum) Could the scoops be effecting the idle? Any suggestions will be greatly appreciated.
Old Jun 20, 2006 | 03:33 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
uhhh... not unless you are trying to idle at 140 MPH... and even then...
sounds like you have a huge vaccume leak or bad senser somwhere. unplug your MAF and see if it makes a difference.
Old Jun 20, 2006 | 05:28 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
correct me if im wrong...but I think his 91 has a MAP, not a MAF. Just had a problem with a code 33, but I could have it backwards.
Old Jun 20, 2006 | 06:39 PM
daves12secV6's Avatar
91+ is speed density,they have map sensors instead of maf,make sure the vacum line is hooked to the map,and isnt broken anywere,if thats all good,get urself oen can of carbcleaner,and spray around all the vacum lines,and places were there would be gaskets on the intake manifold,if the idle jumps up even higher or the car stalls when u do that u have found ur vacum leak.if nothing changes u prolly just have a dead map sensor,
specialized
Jun 18, 2022 09:26 AM
dyeager535
Aug 28, 2015 08:10 AM
mdtoren
Aug 23, 2015 12:52 PM
bryan623
Aug 10, 2015 11:33 AM
