no codes
Old Jan 22, 2002 | 01:27 AM
trans slam's Avatar
no codes
hey guys
I've just switched my 1988 TBI Fbody to 1991 TPI. Everything started up great. Seems to be pretty responsive... But yet I have my engine light constantly on... then after turning the engine off and just turning the key on I can't get the codes out of the light when I jump the two terminals at the ADL port. By the way I'm using a SD harness from Painless. I'm figuring it's something to do with my Map sensor... I'm getting a lot of black smoke during idle. I've got everything alse on the car to work so far- haven't been opn the road yet to try my cruise control though...
Any other suggestions?
Old Jan 22, 2002 | 08:35 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Make sure that one of the terminals in the aldl is a ground. Without a ground in the proper connector it will be impossible to "pull codes" using the two terminal connection method.
Old Jan 22, 2002 | 10:51 PM
u r sofa king we tah did's Avatar
this must be tara's (that self proclaimed cute chick) brother.
https://www.thirdgen.org/techbb2/sho...threadid=78779
first off does the painless wiring harness have the data wire that runs to the ALDL? if it does, make sure your ALDL ground is good. Black smoke at idle indicates rich, so you could have several culprits here. a bad o2 sensor could cause this. also a bad map sensor. among others. you need to get the codes out of the computer somehow
Old Jan 22, 2002 | 11:57 PM
trans slam's Avatar
yes jokes over.... shes my GF
got lots of responses thou
I didn't mean to stir up anything - but I got more respones/hits in the last couple hrs than I have the whole time I've been a member
lates
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
