Cute blonde havin car troubles
Old Jan 22, 2002 | 06:55 PM
Tara's Avatar
Hey guyzz
I've just tried to switch my 1988 TBI Fbody to 1991 TPI. Everything has started up great so far and seems to be pretty responsive... But, my engine light is constantly on. I can't seem to get the codes out of the light when I jump the two terminals at the ADL port (I'm using a SD harness from Painless). Umm, maybe it has to do with my Map sensor?!? :P I'm also getting a lot of black smoke during idle. I've got everything alse on the car to work so far (keep u're fingas crossed!!)
I have to drive down to Florida for Valentines Day (I'm such a sweetiee) ...so, help me out boyzz!!!
Keep cute...Tar.
Old Jan 22, 2002 | 07:11 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Is this light on from the time you start it up or does it come on while driving?? You are jumping the 2 top ports on the right of the ALDL, right??
Old Jan 22, 2002 | 07:53 PM
Tara's Avatar
Ummm, the light goes on and then just doen't shut off while the engine is running...but the light will go off once i shut the car off!! What to do??!!
Thanxs soo much for u're input! I love these car man!!
Tar.
Old Jan 22, 2002 | 08:09 PM
FstBrd6point3's Avatar
doesn't black smoke mean you are running too rich?? the O2 sensor will pick that up and throw an engine light, what size injectors are you using, and hat is the computer from?? what is you ruel pressure at?? you may benefit from turning it down. I dont remember, did U say your car is a 305? if it is and you are running a TPI from a 350, you have 22lb injectors which are too big for a 305 unless you have some good mods. In my experience, black smoke means lots of gas.
Old Jan 22, 2002 | 08:23 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
Black = burning gas
blue = oil
white = water/coolant
PS- got any pics?
Old Jan 22, 2002 | 09:22 PM
blowen90ta's Avatar
is this post somthing or what.dont play the fools.on third gen we even help the ugly chicks.but if you cant get it runnin right i'd bet someone here would like to plug his scanner into your aldl port,flip some switches and grab all the codes that are availible
later
pete
Old Jan 22, 2002 | 09:44 PM
IROCKER's Avatar
Hey Tara...are you from Kingston, ON?!? If so, check out some of us local in the Ontario Region Forum.
Old Jan 22, 2002 | 09:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Heck, I just tuned in for the pic...maybe take a ride over to trans slam's place...seems to be close by...https://www.thirdgen.org/techbb2/sho...threadid=78657
Old Jan 23, 2002 | 12:48 AM
trans slam's Avatar
ya I don't live too far from my GF place. I'll check into that Irockers site too.
I can send you a pic of the car if ya want...
Old Jan 23, 2002 | 09:14 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Hahahahaha. What a great way to get people to check into your post. 175 viewers.
Old Jan 23, 2002 | 09:54 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Cheap trick. By the way, my new name is going to be Hot2Trot.
Old Jan 23, 2002 | 10:01 AM
ploegi's Avatar
Engine: 5.7 TPI
Isnt there some ethics issue here?????? Although, I must say it IS a good ploy, worked on me.......
Old Jan 23, 2002 | 11:19 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
any pics of what you've done?
Old Jan 23, 2002 | 03:08 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Are there any pics of you?
Old Jan 23, 2002 | 03:19 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Come on now, back to tech. The thing to do is get your hands on a scan tool and start going though the sensor data. I have no idea why you would get a SES light and not be able to pull a code.
Old Jan 23, 2002 | 05:22 PM
trans slam's Avatar
well heres a pic of the car some of you requested...
I"m in the midst of double checking a lot of things... I'll get a pic posted of the engine compartment.
Are knock sensors from 305 TPI 350 tPI the same- or different enough to show the black smoke that I'm getting? I requested a 305...
Old Jan 23, 2002 | 07:42 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
trans slam=tara?????
guess I was hoping it was actually a hot chick into out cars. I've only found one so far.
ANYWAY.......
I don't think you can pull codes with the engine running, that does something else, diagnostic mode or something. Just do key on with the paper clip jumping the aldl terminals and then you can read the codes. This always worked for me.
Or just get a scanner so you can get running data too.
bryan623
Mar 22, 2021 06:43 PM
Linson
Aug 21, 2015 02:12 PM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
