Looking for ODDS and ENDS for my TPI build:
Old May 16, 2024 | 12:12 PM
racprops's Avatar
Any stuff that goes with the TPIs, Stock throttle bodies, (I am NOT looking for hot rod parts) nuts, bolts, screws, the bottom parts to the throttle bodies I can use them. I also could use any of the PCMs, (165s only) flex plate bolts, a complete set of oil pan nuts....Thermostat housings, a few of things I am searching for as I missed placed them. Any sensors from a SBC TPI also welcome.
Donations are happily accepted. Or low prices with shipping...
If it is old junk to you it can be a treasure to me.
Thanks.
Rich
Old Jul 11, 2024 | 08:42 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Re: Looking for ODDS and ENDS for my TPI build:
Thanks.
Rich
Did you get the bolts for your TPI build yet? I am going to have the black bolts (with torx heads) that put the tpi together probably this fall. I bought ARP bolts for my tpi that I'm going to install when I do my 0411 pcm swap. I won't have a use for them once I start tearing things apart. Let me know.
Old Jul 11, 2024 | 09:02 PM
racprops's Avatar
Thanks, I bought a set off ebay.
The only part i need is the idle and water heater under the throttle body, I have a cracked one that can be trimmed down the just the idle motor as some like to do.
Can trade.
I feel I might get caught is a snow storm and don't want a iced up throttle plate.
Rich
Old Jul 11, 2024 | 09:29 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I might have one of those. I'll have a look....
Old Jul 11, 2024 | 10:37 PM
racprops's Avatar
Thanks I will keep watch for your word.
ARich
Old Jul 12, 2024 | 06:34 PM
Engine: LT1, L400
I have half of one.
Old Jul 12, 2024 | 07:29 PM
racprops's Avatar
I take it that is just the idle motor section...
I have one.
Rich
Old Jul 14, 2024 | 10:01 PM
Engine: LT1, L400
Sorry, gone for the weekend. Yes, just the IAC section.
I_R_O_C_Z_2_8
19
Jan 21, 2010 08:20 PM
Scotty562
Aug 21, 2006 05:16 AM
blackbeauty
Mar 26, 2006 05:44 PM
