Accessory Studs for Dyno Dons Headers
Old Oct 31, 2024 | 07:20 PM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
I have a ‘88 GTA that is getting a new 355 with Dyno Don Headers. The front bolt on each side is used for a support bracket (AC brkt and Power Sterring brkt). What have you guys used to get to the proper location? I was going to buy some stainless spacers but I think 3/4” is too large for the space to the first header pipe. I saw one guy suggested thick wall pipe.
Old Oct 31, 2024 | 07:31 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Accessory Studs for Dyno Dons Headers
Do you have the studs?
If so email me your address and I will send you some spacers.
I make them from 1/2" tubing with 3/8th inside diameter.
Old Oct 31, 2024 | 07:37 PM
hessm70's Avatar
PM and Email sent! Did you get it?
Old Nov 12, 2024 | 06:33 AM
hessm70's Avatar
Bump
Old Nov 14, 2024 | 09:11 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
In those 2 locations, use the OEM manifold bolts and the sleeve spacers Don sends you.
tlkcurban@comca
Jul 17, 2023 11:46 PM
89formula350b2l
Oct 12, 2019 09:25 AM
Harryballs191
Jan 3, 2018 08:03 AM
1FastZ
Oct 10, 2012 11:19 AM
skinny z
Oct 6, 2008 05:35 PM
