Fuel rail o-rings/seals
Old Nov 13, 2024 | 03:46 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hey guys,
Where can I find, preferably a complete set, of O-rings for the fuel rail? I'm talking about the seals for the crossover pipes, the FPR, etc. I can easily get the injector O-rings. It's everything else I can't seem to find.
Several of my injectors decided to leak when I guess the injector O-Rings failed and I'd REALLY hate to put it back together without replacing everything. I don't want to see a lower plenum with large puddles of fuel ever again.
I have been googling and searching and whatever for these things. Visited 5 gazillion parts house.
(LB9 if it matters but I seriously doubt it does)
Edit: While I'm at it, I'm replacing the Rochester type injectors with the Bosch from South Bay. Any tips, other than the included instructions?
Edit 2: Nevermind. The one place I did think NOT look until after I posted this was South Bay itself. They have a set, hopefully it's what I want. Had to call them because I had problems with the site, BTW, just want to mention their excellent service.
Old Nov 13, 2024 | 03:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel rail o-rings/seals
Standard motors sk24 for rail crossover kit .
if you got the D3 injectors lube the o-rings up and install in the intake first then install the rail. Prime the fuel system a few times check for leaks before putting on the runners.
Old Nov 13, 2024 | 05:51 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Excellent advice. I wish I knew that before I did my TPI conversion. Installed everything and discovered that several of the rebuilt fuel injectors did not pulse. Took it back apart and installed Southbay D3's. Never looked back.
Fred
Old Nov 13, 2024 | 08:47 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
A lot of this stuff has run together in my mind over the years because I work on lots of different GM stuff. Turbo Buicks, Turbo GMCs, Turbo Pontiacs, TBI cars and trucks, and TPI cars.
The fuel rail O-ring rebuild kit is SMP SK24. 9 O-rings. (2 won't be used on 89+ TPI engines because those don't have the 9th Cold Start Injector).
The fuel supply & return line that connects to the fuel rail uses SMP SK18 which contains 1 each SK26 supply line and SK27 return line O-rings. If you aren't touching anything fuel related on the back of the car you only need the SMP SK18 kit.
SK26 has 10 each supply line O-rings (I think these O-rings are also used somewhere on the back end of the car too. Maybe fuel filter and/or rubber fuel supply hose)
SK27 has 10 each return line O-rings
I'm not betting my life on these part numbers. I may have them backwards.
I like to use plain jane Vaseline petroleum jelly for O-ring lube on fuel related O-rings.
Old Nov 14, 2024 | 11:49 AM
Engine: Lb9
Transmission: M20
The sk24 just has a tiny and large o-rings for the csi. Good to know there are other p/n
Old Nov 22, 2024 | 08:05 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Southbay also carries the fuel rail rebuild kit.
Old Nov 22, 2024 | 08:26 AM
southbay08's Avatar
heres the link
https://www.southbayfuelinjectors.co...5-7-83-92.html
formula forever
Jul 17, 2014 06:10 PM
TKO500
Sep 17, 2005 09:02 AM
Ebby
Jul 10, 2005 06:15 PM
Ebby
May 22, 2005 02:21 PM
TimTPIMonte
Nov 8, 2002 10:59 AM
