Need some help on TPI control modules
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
I'm about to start working on a 1984 Berlinetta Starship Edition, it's a carbureted 305 sbc. I want to put a TPI on it but want to make sure that the PROM or Injection Control Module isn't specific to the 305 or 350 blocks. More or less I want to know if I can use a TPI with a 350 PROM on a 305 block.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need some help on TPI control modules
I’m assuming you’re referring to tpi maf, the esc will be fine if it’s from a 350 . You will want to use a calibration chip for a 305 to better control fueling with 19#hr injectors.
