305 TPI to 350 TPI
Old Jul 28, 2008 | 12:20 AM
eric_pomerleau@'s Avatar
305 TPI to 350 TPI
Hi,
Im new here, and im happy to join the group
Thank you for your help
I buy a beginning project, Camaro 1986 305 TPI
Inside the car
Rebuilt a 355, flat top piston with valve relief, 416 head with 1.94 and 1.60 valve ,the machine shop tell is 10.5:1 compression
He have a mild cam and rebuilt injector 19 lbs
The guy tell me ,just use the TPI 305 setup, ECM,PROM,ESC Module and knock sensor from a 305 tpi and everything run ok
after read some site in internet , i see i need change the prom, esc module and knock sensor from the 350
I need advice before , i finish connect everything
If i need use new Prom, someone can help me to program the PROM, or a company can program my prom
Thank you very much
Éric
Old Jul 28, 2008 | 01:23 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: 305 TPI to 350 TPI
I think you need 24 lbs injectors, I'm pretty sure everything is the same but the computer is programed different, but the factory TPI setup doesn't allow good airflow for a 350 to make some good power.
Old Jul 28, 2008 | 08:32 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
"after read some site in internet , i see i need change the prom, esc module and knock sensor from the 350"
This is correct, you should also change your injectors to the stock 22lbers, or change you injector constant to 19 in the prom.
Old Jul 28, 2008 | 06:31 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
