87’ iroc z
Old Feb 24, 2025 | 06:46 PM
BacRoads864's Avatar
87’ iroc z
Wires to this ?? Connector
5 prong plug?? Close to canister
The relay with H1-R with six prongs
…no power to ALDL connector, fuel pump not functioning on ign. In the on position, (bypassed the loop circuit with 12v ign sliced at fuel sending unit connector on gray wire” power”) just seeing if fuel pump worked, had good pressure but injectors not functioning. I am missing canister purge solenoid and there’s a FIVE PRONG FEMALE plug next to radiator.
my question what goes here and what is the small white SIX PRONG relay(under dash) hidden at ecm location with one plug a orange a ground and a pink line orange goes to aldl but pink wire is open. Any help wanted thanks
Old Feb 24, 2025 | 10:50 PM
Vader's Avatar
Re: 87’ iroc z
The blue-white, green/black, and blue/black wires are commonly used on the IAC, but should be nowhere near the radiator shell.
92RS-HeritageEd
Jun 13, 2019 06:42 AM
theurge
Feb 21, 2017 11:36 AM
c0wcommander
Apr 23, 2011 12:39 PM
firebirdjosh
Jul 11, 2005 07:20 PM
383 rocket bird
May 19, 2005 02:31 PM
