Applying 12v directly to the fuel pump through the diagnostic connector?
Old Apr 23, 2011 | 03:58 AM
c0wcommander's Avatar
http://www.justanswer.com/pontiac/2m...nnot-hear.html
One of the posts here mentions how they were able to directly power a fuel pump and bypass the relays by plugging in an external 12 volt battery through the diagnostic connector of an 87 Trans-am. How exactly can this work, where would the positive and negative terminals plug to? I found a picture of the terminal here.
http://ww2.justanswer.com/uploads/am...0_030947_1.gif
Old Apr 23, 2011 | 06:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Applying 12v directly to the fuel pump through the diagnostic connector?
Fuel pump already has a ground (assuming it's not cut/damaged) - so just put 12v to that G terminal in your pic.
But I wouldn't use this as a permanent fix for fuel pump not working. I'd test the relay as mentioned in that first article, and check relay and connector for the relay. 99% of the time the relay (or connector) is the issue.
Old Apr 23, 2011 | 12:00 PM
Yeah, the relay is dead. Problem is I ordered mine online so it won't be here until next week. I have an external 12 volt battery, so do I just plug the positive lead to the G terminal and the negative lead to the A terminal?
Old Apr 23, 2011 | 12:39 PM
Car: 1992 RS
Engine: Carbed 350
Why not just run a wire from the fuse block (right there under dash) to the G terminal?
There is an empty slot marked IGN - use it - it only gets power when the key is on.
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
