Help with 86 Iroc distributor issue
Old Mar 16, 2025 | 07:37 AM
86IrocJoc's Avatar
Car: 1986 Iroc
Engine: LB9
Good morning all. So, I ahave a picture of the distributor on my Iroc. The side piece I have circled has wiring that plugs into the bottom of that piece in the pic. The clips and broke and my car won't start anymore. The clips were going bad and I used to have to push the plug back up into the circled piece there for the car to start. So, I need to buy the connecting harness that plugs into the bottom of the piece. Can anyone please tell me what that little harness/plug is called? Thanks ahead of time.
Old Mar 16, 2025 | 08:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with 86 Iroc distributor issue
Amazon Amazon
might just look at the icm to insure it has 2 terminals on the 1 side.
Old Mar 16, 2025 | 08:52 AM
Engine: Lb9
Transmission: M20
Or if you’re talking about the power and tach
Amazon Amazon
Old Mar 16, 2025 | 02:02 PM
86IrocJoc's Avatar
Car: 1986 Iroc
Engine: LB9
Yep, I believe it's the power and tach one. Will that make my car just shut off while running? And it was hard starting also unless I pushed those connectors up.
Old Mar 16, 2025 | 02:07 PM
Engine: Lb9
Transmission: M20
If you loose power to the distributor, you loose spark and injector pulse on tpi.
Old Mar 16, 2025 | 02:23 PM
86IrocJoc's Avatar
Car: 1986 Iroc
Engine: LB9
Ah man, thank you so much for the help!!!! I should know this stuff since I bought her brand new LOL!! First time i've ever had a problem like this. Thank you again.
86IrocJoc
Mar 16, 2025 08:53 AM
jomalley1234
Aug 4, 2020 11:42 AM
themodifier
Mar 29, 2003 08:50 PM
rockind78
Jun 29, 2001 01:59 AM
