Help with 86 Iroc distributor issue
Old Mar 16, 2025 | 07:16 AM
86IrocJoc's Avatar
Car: 1986 Iroc
Engine: LB9
Good morning all. So, I ahave a picture of the distributor on my Iroc. The side piece I have circled has wiring that plugs into the bottom of that piece in the pic. The clips and broke and my car won't start anymore. The clips were going bad and I used to have to push the plug back up into the circled piece there for the car to start. So, I need to buy the connecting harness that plugs into the bottom of the piece. Can anyone please tell me what that little harness/plug is called? Thanks ahead of time.
Last edited by 86IrocJoc; Mar 16, 2025 at 07:36 AM. Reason: Wrong forum. Should be on TPI
Old Mar 16, 2025 | 08:29 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: Help with 86 Iroc distributor issue
You don't need a new harness, and you don't need the plastic connector that plugs into the cap from the harness.
Just replace the cap and replace the "female" spade connectors of the correct size on the ends of the wires, and plug them in separately.
I upgraded the distributor on my 71 shortbed to an HEI like yours, and did the same tbing.
Old Mar 16, 2025 | 08:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...ml#post6556108
jomalley1234
Aug 4, 2020 11:42 AM
spkx714
Jul 28, 2010 08:44 PM
themodifier
Mar 29, 2003 08:50 PM
rockind78
Jun 29, 2001 01:59 AM
