Fuel issues?
Old Mar 18, 2025 | 01:39 PM
Tony Scotland's Avatar
Car: 1989 Camero Iroc Z convertible
Transmission: Auti
Fuel issues?
Hi, working through the car, 1989 305 tbi. I have replaced the fuel filter, fuel pump relay and complete throttle body. Now have fuel up top. Turn the key on and you hear the fuel pump prime. Turn the motor over and you get a squirt of fuel out of the injectors then nothing. Car runs well off a can of petrol. Any ideas on where to go next? Or how to check fuel pump pressure? Thanks
Old Mar 18, 2025 | 02:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel issues?
You’re saying the injectors leak ? Or just fail to pulse while cranking ?
Old Mar 19, 2025 | 05:15 AM
Transmission: Auti
Re: Fuel issues?
They seem to get a quick pulse when first cranked over then nothing after that
Old Mar 19, 2025 | 08:24 AM
Engine: Lb9
Transmission: M20
Re: Fuel issues?
Is spark consistent ? Sounds like a bad icm or could be a vats issue.
Old Mar 20, 2025 | 03:21 AM
Schurkey's Avatar
Re: Fuel issues?
Connect a scan tool, find out if the computer has an RPM signal when cranking.
Vicious
Mar 31, 2013 06:21 PM
M1tch
Carburetors
19
Oct 30, 2008 08:04 PM
senatorcbp
Oct 5, 2005 08:11 PM
bac67
May 10, 2005 03:59 PM
Palz
Dec 18, 2000 12:10 AM
